M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > DYN-O-MITE Time !
      11-08-2016, 02:40 PM   #1
Orange fever
Orange fever's Avatar
Thailand
2351
Drives: E36M,E46M,E90M,X5M,i3,M2,i8
DYN-O-MITE Time !
So I woke up this pass Saturday morning decided to drive the m2 stop by Costco gas station filled up the tank and decided to visit European Auto Source to do a basic dyno. (Dynojet)
Here are the results on 91 octane (shitty gas from Costco )
we did three runs :
With the same result: 322-329
and the last three runs we decided to add 1 gallon of E85 octane
on 3/4 on 91oct
Result: 340-352
Waiting list :
Software
Downpipes
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged ///
F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87)
Appreciate 4
BruceM984.50
BAN_M2C4185.00
No Boost4021.00
FSociety3812.50
      11-08-2016, 03:02 PM   #2
Jevi Javi
Dominican Republic
80
Drives: e46 M3 + G05 X5
we did three runs :
on 3/4 on 91oct
Result: 340-352
Attachment 1523385
Waiting list :
Software
Downpipes
I guess that is not bad for 91 octane. My car did 350 whp + 417 ft-lbs on 93 octane on a dynojet as well...
No Boost4021.00
      11-08-2016, 03:44 PM   #3
Orange fever
Thailand
2351
I need the ManaJuana for more hp ..Lol
      11-08-2016, 03:48 PM   #4
Jevi Javi
Dominican Republic
80
hahahaha
more than e85 im sure!
haha
      11-08-2016, 05:17 PM   #5
BAN_M2C
BAN_M2C's Avatar
4185
Drives: 991.2 Porsche GT3, BMW E46 M3
1987 BMW 325is  [10.00]
2004 BMW X3  [6.50]
2018 Porsche 911 GT3  [10.00]
1974 BMW 2002tii  [10.00]
2004 BMW M3  [10.00]
hahahaha
haha
Lol Mama Juana in the tank? You did a before and after pulls? Any Mangu in the tank also?
Those base numbers look good OP..
Has anyone tried any Sunoco 100 octane?
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii
FSociety3812.50
      11-08-2016, 07:43 PM   #6
Bimmer28312
Bimmer28312's Avatar
Drives: BMW N55 335xi
I'm planning to do a stock run on 91 octane and 100 octane with jb4 as soon as they have an open slop for me. Hoping this week
BAN_M2C4185.00
jofus1.50
      11-08-2016, 09:27 PM   #7
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Costco is by far my fav gas for the past solid year.
Its the most consistent station to station gas brand I've used in my X3 and X4 M40i.
Heck, those are solid results for 91 and wow 439wtq with just 1 gallon of e85
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      02-05-2017, 01:12 PM   #8
NO_USER_
538
Drives: .
Does the car run lean with that extra gallon?
      02-05-2017, 05:36 PM   #9
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
They run lean from factory but an extra gallon of E85 won't make it much leaner that one should worry about.
IG: @bmwF9XG80
      02-05-2017, 06:47 PM   #10
NO_USER_
538
Drives: .
What should the AFR be? What if you added two gallons of E85? Is that safe, without tuning. To raise 91 octane to 93. Thanks!
      02-05-2017, 11:09 PM   #11
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Here's a real world AFR example. 4th gear 3k-7k with e15 left over from last fillup. Mostly 93
The m2 actually runs a bit rich compared to other n55's. Normal is 12:5:1, the m2's stock tune dips into the 11's.
      02-06-2017, 06:41 AM   #12
PackPride85
Drives: M2
Most DI motors can be tuned safely to run mid 12's for AFR.
      02-06-2017, 08:29 AM   #13
NO_USER_
538
Drives: .
Thanks! Did you have any tunes or mods when you took that datalog?
      02-06-2017, 10:41 AM   #14
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Yes I have an Intake, catless DP and JB4 for logging. So my settings may be oscillating AFR's a bit but JB4 doesn't effect Lambda/AFR's directly. Just the fuel pressure sensor. I can do a log in map4 and will post to compare
Honestly I'm glad the m2 has thicker AFR's. A lot of times people running this setup on the m235i have scary lean AFR's considering the torque curve hits so hard, so quickly.
Does anyone on here have experience with the ECU psi going above the DME boost target?
      02-06-2017, 10:43 AM   #15
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Yes and this just about terrifies tuners that haven't tuned a di BMW or are used to a less sophisticated DME lol.
      02-06-2017, 11:27 AM   #16
NO_USER_
538
Drives: .
Thanks! I really appreciate it. Which downpipe and intake are you running? So the log you already posted, its on the stock map correct? Does the catless downpipe cause boost spikes or boost creep on the stock map?
Thanks!
      02-06-2017, 11:29 AM   #17
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Thanks!
I'm dealing with the ECU psi reading above the DME boost target. Could be due to the downpipe but I'm not sure. BMS I take running Mafless and VRSF downpipe.
The ECU psi could be causing throttle closures.
      02-06-2017, 11:44 AM   #18
NO_USER_
538
Drives: .
There's no MAF? You can do that??
How much higher PSI are you seeing? What's stock boost set at?
      02-06-2017, 12:35 PM   #19
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
The maf on the n55 is for idle and low throttle emissions. The n54 doesn't use a maf. It's a JB4 option for people with lumpy idles due to the extra flow some intakes provide.
      02-06-2017, 12:41 PM   #20
NO_USER_
538
Drives: .
Wow that's good to know, thank you sir! Do you know if the Eventuri intake would cause that by any chance?
So under throttle what does the car use if it's not using the MAF?
      02-06-2017, 12:58 PM   #21
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
I haven't heard if it does or doesn't. If they copied the factory flow it won't. The BMS I take flows a lot more so it causes little hiccups like that. I just like that it wasn't a factory clone.
Actually the DME BT and ECU psi aren't as far off as I thought. JB4 is probably just learning.
The factory DME targets up to 14-15.5psi I believe. Hangs in the 11-12 range most of the time
      02-06-2017, 01:09 PM   #22
NO_USER_
538
Drives: .
Thanks! What's the benefit of not having the factory flow? Are you aware of any other intakes that are similar to BMS?
Also, how's the induction sound with the burger unit? Thanks!
m2
