M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Best way to tap into manifold or boost pipe (Pre TB)???
      11-03-2016, 07:34 PM   #1
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2020 BMW X4M CS  [0.00]
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
Obviously you could drill into the intake manifold, but obviously that would require removal due to the drill shaving possibly falling into the manifold...
Seems there are no pressurized lines, any hoses running away from boosted parts have one way valves to store vacuum....a
I have a boost activated exhaust valve and need a manual boost source
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3
MDriven141.50
      11-03-2016, 07:59 PM   #2
Twix
Twix's Avatar
657
Drives: 2011 e91
Drilling into the intake won't get you vacuum since the engine isn't atmospheric. There is a vacuum pump on the engine somewhere. You could tap into the power brake booster line from that pump.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      11-03-2016, 08:26 PM   #3
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
Well I said I wanted to tap into the manifold post throttle bosy not the intake...And the Brake booster is run on vaccum w a canister so i believe its a one way valve that stores the engines vaccum when ur not in boost...
If the M3s brake boosted was assisted by boost and not vacuum assisted it be the first car ive heard of in hisory...
Dinan has a manual adapter that goes in between your MAP sensor and manifold and has a 1/4 manual boost line to hook a hose too...I need something like that
      11-03-2016, 08:28 PM   #4
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
I think you misread and though i said vaccum....To clarify I need boost...
      11-03-2016, 08:43 PM   #5
Twix
Twix's Avatar
657
Drives: 2011 e91
I did. If you have a charge pipe, they usually have options for bungs on them for tapping boost.
I can't see anything on realoem
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      11-03-2016, 10:25 PM   #6
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
yea my meth bung which has no vacancy ATM lol.
I found a spot to grab boost pre tb. which should be fine... jw/ if anyone else has needed this and if theres an adapter or easy fix
m2
