10-25-2016, 10:11 PM | #1 |
1419
Rep 2,560
Drives: Rapidly from A to B
M2 ground control camber plate settings
Ordered some camber plates from GC. They have 3 or 4 fixed camber settings. Can someone tell me the camber at each setting. For example:
Setting 1=stock Setting 2=stock-x degrees Setting 3=stock-y degrees ..
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
10-26-2016, 01:49 PM | #2 |
Rep 1,084
I'm pretty sure GC plates have continuous adjustment... Also, have you asked GC for those specs?
rwalker@rwalker.com (I really dislike Private Messaging)
cappy6960.00 |
10-26-2016, 04:06 PM | #3 |
1419
Rep 2,560
They have fixed setting for the M2. Awaiting to hear back from them.
10-26-2016, 06:55 PM | #4 |
2276
Rep 2,515
I have them. They are not fixed. Infinite adjustments within fixed range.
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo ?22 Tesla Model Y Performance Midnight Silver/White |
10-26-2016, 07:15 PM | #5 | |
1419
Rep 2,560
11-07-2016, 09:31 AM | #6 |
2051
Rep 3,714
04-10-2017, 11:09 PM | #10 |
Rep 120
04-11-2017, 01:13 PM | #13 |
Rep 123
Looks terrific so far. A little over 1500 miles total (950 highway down/back, ~300 track miles).
They really look good. I'd've taken a picture, but there was nothing to see! As for the rear, around -1.6 or so. Stock as delivered, and just left it there with a tad of toe in. Running the stock staggered PS2s, the rears seemed to hold up fine. |
04-11-2017, 10:00 PM | #14 |
2051
Rep 3,714
Does more negative camber change clearance between the tire and the strut? Or does the relationship stay the same? Right now I have just enough clearance on the inside on the stock alignment
04-11-2017, 10:43 PM | #15 |
Rep 120
Pretty sure it would not. That should only be affected by your wheel size and offset.
04-12-2017, 06:36 AM | #16 | |
1419
Rep 2,560
04-12-2017, 08:05 AM | #17 |
Rep 123
Nope. My max camber is currently limited by the stock spring to the inner fender well. I left a pinky finger's clearance. With 60mm springs, I could get even more from the plates if I wanted.
05-15-2017, 04:11 PM | #18 |
Rep 54
We installed GC plates on one of our M2's. Everything else was oem. We could get up to -4.5 degrees in the front. We set the front alignment to -3.0 degrees camber, zero toe and max caster. In the rear we ended up at -2.0 degrees camber and zero toe. Car was rock solid under heavy braking and tire wear was even inside to out on a set of Hoosier R7's (265 front 295 rear) on 19" Forgelines after 250 track miles at Road America.
05-18-2019, 02:40 PM | #19 |
Rep 195
I have GC plates installed but the most they're able to get is -2.2 deg. Am I or my shop missing something?
2017 M2|LBB|Manual|Executive Package|Fabspeed SportCat|Dinan S4 Tuner w Big Turbo|Remus Exhaust|Dinan Intake|Dinan Intercooler|Dinan LPFP Upgrade Kit|Ultimate Clutch Pedal|BMS Clutch Stop
05-18-2019, 03:43 PM | #20 |
Rep 650
