M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > BMS intake, CEL P120D
      07-06-2016, 05:18 PM   #1
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
So does anyone know what this code means???
P120D
It's happened twice with my BMS intake.
BMS is unfamiliar with the code, and said they won't be able to assess until I get back to them with a description of this particular code
So has anyone else had issues with the BMS intake???
Thanks in advance
-c
2016 BMW M2/LBB/6MT/Exec Pkg
2009 Acura MDX-stock
2008 Acura RDX-stock
2005 Honda S2000-mostly stock
1994 Nissan 300ZX Twin Turbo-barely stock
      07-06-2016, 06:08 PM   #2
DrKevM5
DrKevM5's Avatar
Drives: G05 X5, F87 M2
I'm getting the same code. I had it cleared, but it still persists. I wonder if the M235i installs have had the same problem.
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo
?22 Tesla Model Y Performance Midnight Silver/White
      07-06-2016, 06:10 PM   #3
DrKevM5
DrKevM5's Avatar
http://www.datsc.com/technical-resou.../hex_/decimal_
      07-06-2016, 06:15 PM   #4
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
Originally Posted by DrKevM5
Great; I'll forward this to BMS. In the meantime, my stock airbox is going back on....
-c
      07-06-2016, 06:58 PM   #5
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
P120D
Thanks in advance
-c
Damnit I just ordered that intake....
      07-06-2016, 06:59 PM   #6
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
This DME responds differently. My catsim is acting up too. Was fine. Wiring is fine. Really touchy car.
      07-06-2016, 07:00 PM   #7
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
Well, my tech (who owns a modded m235), has said his customers have had "hit or miss" success with the BMS intake (in terms of a CEL).
I forwarded your info regarding the code to BMS, and the response was less than satisfying:
BMS:
I don't see how the intake could be related to a throttle position code. The throttle position sensor is in the throttle body near the intake manifold. The intake itself would have no effect on this sensor.
Best,
Jon
BMS
How about anyone here with a CEL email/contact BMS and tell them we are all getting the same code...
Thanks guys
-c
      07-06-2016, 07:25 PM   #8
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Well, my tech (who owns a modded m235), has said his customers have had "hit or miss" success with the BMW intake (in terms of a CEL).
BMS:
Best,
Jon
BMS
Thanks guys
-c
I'll install and do that if it comes up
      07-06-2016, 07:30 PM   #9
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
Thanks. I admit it's a strange code. And this car is probably pretty finicky. However, I just think their response was a bit flippant, as if they didn't believe it could happen.
And I SWEAR, even before I knew what the code meant, this afternoon, while driving (CEL already present), I thought that the car was idling just a TAD bit rough. Since getting home from work, I have gone back to the stock airbox. CEL is still there, but the rough idle is gone. Again, I thought the car was idling rough BEFORE I knew what the code meant...
Again, the price we pay for being impatient early adopters
-c
      07-06-2016, 07:34 PM   #10
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
And you probably know this, but when installing, do NOT follow the PDF instructions. If you have a 6MT, you still do need to connect the vacuum hose to the intake, not leave it hanging and cap off the inlet hole on the intake, like BMS's instructions say. This was confirmed by another board member (I don't know how to post screen names), who also followed the directions, then contacted BMS when he got a CEL. However, we both have since installed the intake correctly, cleared the code, and in both cases the CEL returned.
-c
Appreciate 4
      07-06-2016, 07:44 PM   #11
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
-c
Bummer. Thanks for letting me know! Yeah I had a rough idle due to catless DP and the catsim. Took off the catsim and will just be living with the code until my jb4 comes in. I will be sure to run intake only and let you know if I get that same throttle code.
      07-06-2016, 08:15 PM   #12
BD_F22
BD_e92
Drives: 2015 m235i xDrive
I had that intake on my m235i and was getting the same code, switched back to stock and never got it again! Unfortunately a lot of these open cone intakes throw codes, BMS is not the only one from the m235 platform.
      07-06-2016, 09:31 PM   #13
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
The same exact code? Interesting. Because Terry from BMS replied:
Terry:
I know a few M2 customers are running the intake and haven't received
this fault code. Did you read the code with a BMW tool so we can see
what it actually is? I suspect your OBDII description is incorrect. If
it's a MAF sensor related fault then it would be intake related.
I don't know how to reply; I'm simply giving them the code that has shown up twice now...
-c
      07-07-2016, 02:14 AM   #14
Eugene-TAIWAN
Eugene-TAIWAN's Avatar
Taiwan
249
Drives: E92 M3 Coupe
get a drop in filter, with the stock box and you'll be fine
Past: Gintani stage3 M3, Cayman GTS
present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW
      07-07-2016, 05:14 AM   #15
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
That's what I had...and it's back in now...just gotta reset the CEL
-c
      07-07-2016, 09:52 AM   #16
Twix
Twix's Avatar
657
Drives: 2011 e91
You using the A74 sim? I've heard they work fine for the regular N55 engines.
Hearing about all these codes makes me want to sit back a bit and wait for companies to actually put some R&D time into their products for the M2.
I don't want to be driving with the CEL on, mostly because it annoys me and also because I want to know if I get a code unrelated to the catless DP or the intake, i.e. fuel pump or injector or whatever. This CEL business on these intakes and DPs makes me sad
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      07-07-2016, 10:02 AM   #17
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Yeah let me say that it could be install related. With that being said I've installed it 7 times. Tried everything. I would be very surprised if it was that. The 02 harness post clip could be damaged.
I wouldn't NOT but it. Just try and see how it works for you. I will be buying a new harness and trying again. I'm catless so the code is inevitable. I plan to flash tune once I move on the a bigger turbo. I'm not worried about it.
      07-07-2016, 10:07 AM   #18
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
I'm really hoping this is all due to the vaccum install error. Burger should really point this out in a new instruction manual.
That's the common factor between the two cars throwing this code. Hopefully mine doesn't.
      07-07-2016, 11:06 AM   #19
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
I was hoping for that too; however, I have since installed correctly, and still the code persists
And I did tell BMS about the faulty install, and they didn't mention that as a possible reason
And I agree, they really gotta fix their instructions
-c
      07-07-2016, 02:05 PM   #20
kevlee23
kevlee23's Avatar
72
Drives: 2008 e92 335xi, F87 M2 AW EXEC
-c
So your running just catless no cat sim leaving code on? I'm doing my catless downpipe next week no tune no sim waiting for a good tune to be made
      07-07-2016, 05:11 PM   #21
Bigcatkian
Bigcatkian's Avatar
103
Drives: F87 M2
Im in the same boat as you right now im running the catless downpipe with no Sim or tune and the code is tripped but it hasn't worried me too much. I might pick up the BMS can flap module to delete the CEL until a proper tune is released
2016 F87 M2 (current)
2019 Gt2 RS(current pipedream)
2016 Cayman Gt4(sold)
2010 E93 M3 (sold)
2012 Wrx Sti (sold)
      07-07-2016, 05:30 PM   #22
Twix
Twix's Avatar
657
Drives: 2011 e91
Thanks! I plan on being catless as well. Hopefully it works.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
m2
