E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Windshield Washer Fluid Pump Replacement
Reply
      05-28-2016, 09:41 PM   #1
Air Drop
Air Drop's Avatar
36
Drives: 08 E92 335i
So no s*it there I was, approaching my car one morning to see a stream of blue fluid streaking from the area of my front right tire. Washer fluid it was indeed.
After a bit of research, I figured my windshield washer fluid pump had cracked; so I ordered a new pump and a new grommet and set out to install.
What you need:
11mm deep well socket & extension
10mm socket
8mm socket
Panel Clip Removal Tool
Floor Jack
Jack Pad Adapter
Bucket
How to execute:
1: Loosen lug nuts on front right wheel
2: Jack up car using front right jack pad (use jack stand to be extra safe)
3: Remove front right wheel
4: Use 10mm socket to remove two nuts; one nut is straight line of sight, the other is below the car just back from the wheel well opening
5: Use a 8mm socket to remove ~7 nuts from the wheel well shroud. 1 8mm nut is below the car.
6: Use panel clip removal tool to remove single panel clip under car, just back from wheel well opening.
7: Remove wheel well shroud
8: Look inside quarter panel, and you will see the windshield washer fluid reservoir. Remove 1 x 10mm bolt from the reservoir, and pull the reservoir and pump into full sight.
9: Place bucket under pump and reservoir
10: Remove electric plug from pump
11: Remove fluid tube from pump
12: Pull up on pump to remove; the OEM grommet is a two-piece unit; the filter may remain in the reservoir; use needle nose plyers to pull this piece out. Expect fluid to drip/flow out during this, hence the bucket.
13: Install new grommet (push down hard to insure it sits well), then install pump, reattach fluid tube and electric plug.
14: Fill reservoir with fluid; check for leaks.
15: Go in reverse order steps 1-8.
16: Done.
Total time is approximately 1 hour for a first time execution.
One note: a triangular piece of plastic on the actual reservoir holds the pump in place, to ensure the grommet sits well. This piece had partially broken off on my reservoir and ultimately caused the leak. I used a silicone sealant to seat the pump properly; I also applied this sealant around the grommet to prevent pressurized up-seating or leaks.
Good luck
-Mike
2008 335i 6MT Coupe
Sapphire Black Metallic / Saddle Brown
Appreciate 5
      05-29-2016, 05:01 PM   #2
Three_thirty_I
Three_thirty_I's Avatar
South Africa
200
Drives: '05 E90 330i Manual
This will come in handy one day I reckon!! Thanks!!
BMW E90 330i (M) '05 (His) | (Hers) BMW E46 320i f/l (M) '03
      11-10-2017, 02:43 PM   #3
Olda_H
Czech_Republic
Drives: 328i xdrive
great thanks
      11-16-2017, 04:18 AM   #4
Dezy152
Drives: black BMW
Very well written information. Keep up the good work. Thanks.
      08-11-2019, 08:53 PM   #5
austin.tillison
Drives: 2006 BMW 325i
2006 BMW 325i  [0.00]
thank you! finally fixed mine today after not having functioning windshield washers for 5 + years lol
      06-26-2020, 09:25 PM   #6
AamirAtl
Drives: 2008 E90
Thanks for the detailed post. My reservoir is also leaking and I am suspecting it is a cracked pump like others have experienced. After reading your detailed instructions, I feel well-prepared to attack this. And since I've removed the front bumper to replace a headlamp previously, I'm familiar with the wheel well area. Hoping to knock it out quick. Thanks again for your post.
      12-16-2021, 05:45 PM   #7
rv7charlie
Drives: BMW 328i
Many thanks for documenting this; I just finished replacing my pump by following your checklist.
One addition: on my 2008 328i, the 10mm devices are nuts, and the 8mm are actually screws. No idea whether BMW changed their attachment method in midstream; this car is my 1st BMW.
Charlie
      05-14-2022, 01:56 PM   #8
mehrlovin
Drives: 2007 328xi E90
Where should you put the jack stand if the jackpad is on the BMW slot?
Reply
e90post
