05-27-2016, 03:55 AM | #1 |
Rep 943
Drives: 2012 328i Modern Line
Help with fault codes
On my '12 328i I am getting several fault codes that I can't figure out. I was hoping someone here might be able to help out.
Things I have coded: halos too 100% with headlights on Front corner lights off (turn signals still flash) M Performance splash on cluster Removed disclaimers (PDC & I-Drive) DVD in motion Phone ringtone Separate cluster/ambient brightness control Turn signals set to 5 TPMS temp & pressure on I-Drive A.S.S. remember last setting A.S.S. disabled notification on cluster Actual speed on cluster I have factory: Xenons with auto leveling Auto high beam assist LED Lighting package These are the fault codes I'm getting on buddies Autologic reader: Front Electronic Module (FEM) (FEM_20) 8041C3 Lamp Mapping Failed D90D37 Interior Lighting Unit (ILE) Incorrect Version Installed High-Beam Assistant (FLA) (FLA_20) E0EC07 KOMBI Interface (kilometre Reading/range, 0x330) Signal Invalid Central Gateway Module (ZGW) (ZGW_1) CD0487 ZGW Synchronization process for FlexRay failed CRASH SAFETY MODULE (AIRBAG) (ACSM4) 930AB3 Indicator lamp for front passenger airbag Deactivation Short Circuit to B+ DIGITAL MOTOR ELECTRONICS (MOTOR) (MEVD1724) 195013 Fuel Differential Pressure sensor, tank ventilation system, working area: absolute pressure too low I do know that the cornering function (fogs) only seem to work when I turn to the left, when I turn to the right my right fog does not come on like it should.
:wave:
