Stereo 2/4 Harness
04-06-2016, 07:08 AM | #1 |
281
Rep 1,525
Stereo 2/4 Harness
I am interested in the Stereo 2/4 Harness. But on Technic's website it says not suitable for pre 0909 production.
Why is this? What change was made at this time? http://technicpnp.com/product_purcha...E90-92-93.html Last edited by E60525d; 04-06-2016 at 11:49 AM.. |
04-06-2016, 11:39 AM | #2 |
1921
Rep 13,122
It tihnk it says pre or post 9/09
And I think the difference is the parallel speaker connection split takes place between the under seats and the doors takes place in the kick panels instead of at the under seat speaker connector. So to split the parallel connection you have to rewire at that point an it has no connector so it must be un hardwired. |
04-06-2016, 12:09 PM | #3 |
281
Rep 1,525
Ok understand. Is there any other way to connect a 4 channel amp without cuttings the factory wiring?
I am guessing one way is to make my own plug and play harness using this? http://masterantena.soteshop.pl/uplo...fhjfjhfhjg.jpg Will this work? (very simple quick diagram) Basically I have got the front left and right cables going to the amp as the high level inputs. I then connect the two subs directly to the amp. And I also also connect the other 2 channels from the back sending the signal to the front speakers. Or is this seriously flawed?? |
04-06-2016, 04:01 PM | #4 |
1921
Rep 13,122
You have to split the parallel wiring in the kick panel
is the bottom line. Then run the line coming from the head unit back to the trunk for the amp. And run one channel to each front speaker location . The ones for the door can be connected at the kick panel door input location. First job locate the parallel connection point. |
04-06-2016, 05:29 PM | #5 | |
281
Rep 4,121
04-06-2016, 07:30 PM | #6 |
1921
Rep 13,122
4/6 harness does not work as intended on cars
before 9/09 I think The problem is because the parallel connection between the doors and floors is not made at the under seats, at least that is the way I understand it. I meant 2/4 in this entry. Last edited by ctuna; 04-08-2016 at 12:47 AM.. |
04-07-2016, 05:40 AM | #7 |
281
Rep 1,525
Thanks for the replies.
I am not sure why I have to split the parallel connection at the kick panel? I will be disconnecting the plug at the subwoofer. The signal from the amp will be connected to the output on the factory harness. Therefore the sound from the amp will go to the front speakers and NOT the sub as it has been disconnected. Edit - I was planning something similar to this, http://www.e90post.com/forums/showpo...50&postcount=2 Last edited by E60525d; 04-07-2016 at 06:14 AM.. |
04-07-2016, 08:12 AM | #8 | |
281
Rep 4,121
Technic of course is best to consult. |
04-07-2016, 11:39 AM | #10 | |
281
Rep 4,121
04-07-2016, 11:04 PM | #11 |
1921
Rep 13,122
But technic himself says it won't work on his site
For cars built before 9/09 "Stereo 2/4: for use with a 4-channel amp to power the front and underseat woofers. Rear speakers are powered by the OEM HU/iDrive unit. No need to remove OEM HU/iDrive unit.. Not applicable to Stereo systems with 2-wires at the woofer connector (pre 0909 production). Stereo 2/4 harness does not provide remote turn on signal. " Which is what the OP says he has. Also I meant 2/4 where I said 4/6 before. Oh I see you meant the 4/6 even tonight. guess I didn't catch that. Last edited by ctuna; 04-08-2016 at 12:46 AM.. |
