amplifier install
03-24-2016, 06:26 PM | #1 |
281
Rep 1,525
amplifier install
Bmw offer a Alpine amp that fits under the boot/trunk carpet. I believe this amp is a class D.
My question is, is it advisable to install a Class A/B amp here? I am told that these run hotter than a class D. Thanks |
03-24-2016, 08:22 PM | #3 |
Rep 145
Class A/B will run hotter than Class D. I guess I'd be more worried about fitment since Class AB will have a larger footprint than Class D with the same current capability.
03-27-2016, 01:04 PM | #4 |
281
Rep 1,525
Thanks for the replies. I have got a question on how to best install a 4 channel on the factory HU. I have done lots of reading and I believe I have a few options.
I am not an audiophile, just want to boost my base system which I will be replacing the mids and subs with L7 one's and adding tweeters. The front mid's, tweeters and subs will run from the amp with the rear shelf speakers from HU. 1. Use existing connections to connect amp via the speaker high level inputs. This was my preferred option but I have seen others with noise with this setup. http://www.e90post.com/forums/showthread.php?t=1239613 Is this method viable without getting any interference or noise? 2. Similar to option 1 but add a LOC which inturn connects to amp. Is this option any better than 1? 3. Code system to hifi, add RCA's on exiting speaker wiring and connect to amp. Will this work, is it better than option 1? By coding to hifi i believe the rear speakers will not work? Correct? 4. Use an amp with "BALANCED DIFFERENTIAL INPUT". I believe this is the best way but there are not many amps with this feature. JL amps have this feature but they are over my budget. Any advise? |
03-28-2016, 03:34 PM | #8 |
1920
Rep 13,122
Unless you recode or use a freqency flatten-er
Unless you recode to Hi Fi or use a frequency flatten-er
with the base system you can't get a good eq curve. This is documented in the audio build thread and many other threads and builds. The cheap guys solution it to set the crossover frequency to - db but you have to have aftermarket speakers with crossover to do that, and it is not the best path. http://www.e90post.com/forums/attach...1&d=1411521234 There are many solutions in the links I posted and the audio build thread also describes exactly what to do. If you want audiophile noise free sound using locs or frequency flattening devices is never the best solution, but it may be a cheaper one which is why its done. Last edited by ctuna; 03-28-2016 at 03:41 PM.. |
03-28-2016, 04:00 PM | #9 | |
281
Rep 1,525
I am not an audiophile, just want to give the system a boost. My current system is the base stereo but fitted with front tweeters, L7 mids and underseat subs. |
03-29-2016, 03:58 AM | #10 |
281
Rep 1,525
Think I found an amp which a good specification and suits my needs, http://www.rainbow-audio.de/en/amplifier/dream/
Any views on the Rainbow Dream 4? Thank you |
03-29-2016, 04:56 PM | #12 | |
281
Rep 4,121
