Valve Cover Gasket Leak - anyone know how to fix?
01-01-2016, 07:42 PM | #1 |
Rep 93
Had a service the other day and apparently it's leaking, although must be slow I haven't noticed anything or had any issues, but thought I'd see if anyone on here knows how to fix it in the Denver area? Did some searching and it could be a DIY, would certainly throw some cash! Thanks!
01-03-2016, 09:25 AM | #3 |
179
Rep 527
It's not that easy, but surely isn't that difficult. Grab a Bentley for help, it has some good info and all the torque settings. I'm actually doing it to my car as we speak. Hopefully I'm done tonight, but I'm also changing the ofhg and serpentine belt and pulleys as well. There's some good videos out there too. Watch them a lot.
01-03-2016, 09:49 PM | #6 | |
525
Rep 1,527
But really, the job isn't that bad as long as you take your time and double check your work. Would also be a good time to replace plugs if they are due. Since you'll have it torn down that far. |
01-04-2016, 10:11 AM | #7 | |
Rep 758
Drives: 2007 BMW 328xi Wagon
There is a great DIY on this forum that gets you through everything. There are a couple youtube video's too. Also look at pelican parts for instructions. Ditto that the hardest part is getting the valve cover on and off. Took like 25 mins to get it on, I was being careful not to break it and it's just a pain to line up. I replaced the cover, gasket, bolts, and spark plugs all at the same time (you cannot reuse the bolts). You will need u-joints and extensions to get at the bolts at the rear of the engine.
2007 328xi Wagon, Black Sapphire Metallic, Sports Package, Cold Weather Package, Rear PDC, Airlift kit with 3P mgmt, CF Akrym rep lip, LCI M-Tech front bumper, LUX Angel Eyes, Black Kidneys, LED Interior Lights, M3 Steering Wheel with Extended Billet DCT Paddles, 19" Staggered VMR 710's
01-04-2016, 10:19 PM | #8 |
915
Rep 3,456
Drives: Harrop E90 M3
I've done plenty of them and they're not that bad. If you have the plastic valve cover it's often the cover that is warped/distorted and causing the leak to occur. If yours has the plastic valve cover its worth buying a new one and installing it. It comes with the gasket and makes the job a lot easier.
01-10-2016, 04:50 PM | #9 |
Rep 93
Thanks fellas, in my situation it's probably worth getting it professionally done, I'll price out some options - when do you guys think it REALLY needs to be fixed? If I see oil leaking in my parking spot, check the oil and see it's going down rapidly, etc? Thanks!
01-10-2016, 05:04 PM | #10 |
764
Rep 10,033
If your car is still under 70k miles, BMW will replace it under the emissions warranty that comes with these cars.
TiAg FTW! |
01-10-2016, 05:06 PM | #11 |
Rep 93
01-10-2016, 05:10 PM | #12 |
764
Rep 10,033
You're welcome That's how I got my VCG fixed.
TiAg FTW! |
01-10-2016, 09:26 PM | #13 |
915
Rep 3,456
Emissions warranty is based off the state in which the car was originally sold. If you don't know, I can look that information up for you. Shoot me a PM and I'll take a look.
01-10-2016, 09:29 PM | #14 |
215
Rep 1,818
Damn... does this apply to valve cover as well? And if the car is sold in ca, would bmw na do the work in another state if that's where the car ended up?
01-10-2016, 09:33 PM | #15 | |
915
Rep 3,456
