01-01-2016, 11:59 AM | #1 |
Rep 64
Question on winter rims
Just picked up the 2016 235ix on the 28th and yesterday installed the winter set up from previous '13 335 Msport. The shows are 225/45-18 and original tires are 225/40 and 245/35-18. Offset on winters make the rubber stick out approx. 3/8 of and inch wider and diameter is approx. 1 inch larger. Does this present any obvious issues? Will speedometer read be inaccurate? I assume the larger diameter will change the gearing but hope it's a minor issue. Any thought are greatly appreciated. Car is X drive.
01-01-2016, 06:43 PM | #2 |
5260
Rep 5,874
As long as no rubbing and all 4 tires are same diameter (or within OEM 1.6% difference), you'll be ok. The speedo will be slow by 3.5% so when it reads 60mph, you're going 62.
http://rimsntires.com/specspro.jsp |
01-05-2016, 05:54 PM | #5 |
Rep 64
I tested that before driving by turning sharp both ways in driveway but I should take a light and check inside wheel wells. I assume I'd hear it as I've put about 50 miles on the last two days. Thanks again.
01-05-2016, 10:31 PM | #6 |
5260
Rep 5,874
When I've had taller tires that rubbed the liner in the past I could definitely hear it on turns. You're probably in the clear which gives me hope for going with 225/40/19 in the front.
