Need help understanding benefits differences between MHD, Cobb, JB4
12-04-2015, 08:37 AM | #1 |
2033
Rep 8,339
I'm coming close to the build date. It was on hold for a year and now I'm ready to proceed. Since it went on hold some new things have come out. Outlets, fuel rails, etc. The one I don't know enough about is MHD.
Originally I had planned a JB4 G5 stacked with a Cobb v3 and a tune by Dzenno of PTF. I have all these in hand including remote dyno tuning. The build is to long to list but here's the basics and link to my build thread. I update the first post to keep if current. Vargas stage2+ Vrsf charge, downpipe, 7"fmic, inlets Motiv fuel rail and 1000 hp clutch 29psi boost on e85 Etc etc etc. So basically maxed out with everything, what benefits or losses would an MHD app tune give me? I don't plan on continuously changing tune. It's a fire and forget for me. I don't care about bells and whistles I don't want displays anywhere. Not a fan of apps, smartphones, etc. I'm old school. This is why I'm clueless about it. I use my phone because I have to for work or I wouldn't even own one. If it will add performance or durability, I'd be interested. Otherwise, I really don't care. Thanks for your help.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
12-04-2015, 09:06 AM | #2 |
Rep 841
Jb4 cobb stack has not been going well for people... So you would want to stack MHD AND JB4. If you really need a stack..
Mhd can do all you need alone and its cheaper. Ive had each one and im currently using mhd and i wont go back to the others ever. Just like any other car.. you do not just tune it and forget about it you need to take logs every once in awhile and make sure the car is running properly sometimes tunes need slight adjustments and other times you will see early symptoms of parts malfunctioning through your tune. Sidenote...mhd is so easy to use, dont get all nervous about it. Its very plain and simple. |
12-04-2015, 09:07 AM | #3 |
Rep 1,093
Dzenno will have a few more tables to play with with MHD but in your case I would really just consult him. Why take our advice when the guy doing the tuning is familiar with all options. At the end of the day there would be no difference. Boost by great can be done with jb4 which you have decided to control boost anyway. I don't think anything else is significant enough to matter but that's just my opinion.
12-04-2015, 09:10 AM | #4 | |
Rep 841
12-04-2015, 09:16 AM | #5 |
2134
Rep 3,553
with what you are planning, jb4 stacked with MHD is going to be your best option vs flash only. Can use a Cobb if you want, but wont be able to take advantage of the new maps and logic, as well as any new progress that comes.
JB4 can implement almost anything into it now at this point. Terry is really changing the game with it right now. |
12-04-2015, 09:26 AM | #6 |
2033
Rep 8,339
I can't return the Cobb. I've had it too long. Would it make sense to do all 3? Any benefits? Just sell cobb? Any downsides to mhd? Keeping the jb4. Not intimidated by it. It's just irritating. I prefer windows 98 personally. I dont like changing and relearningthings every few years. If the car had a coyote or 350 small block with twin 4 barrel carbs I'd be tickled pink.
12-04-2015, 09:30 AM | #7 | |
Rep 841
And yeah try to sell it |
12-04-2015, 09:32 AM | #8 |
2033
Rep 8,339
12-04-2015, 09:34 AM | #9 |
2033
Rep 8,339
Where do you get mhd? Price, etc. What do you need to get it working? I think it's a phone app. Once the phone flashes the cpu, do I need to keep phone hooked up or that's it? All new to me.
12-04-2015, 09:39 AM | #11 | |
Rep 841
On the tablet there is an App store. You purchase MHD software on the tablet. The tablet or phone does NOT need to be plugged in constantly..only when flashing a map or data logging. Your tuner can really explain all of it to you since he has experience with it. Best bet is to get him on the phone and settle it. |
12-04-2015, 09:46 AM | #13 |
Rep 841
12-04-2015, 09:48 AM | #14 |
2134
Rep 3,553
should work. cobbs are going for a good price on ebay. on here, around 400
or use the cobb. PTF will be able to get you a good tune with the cobb, and if you arent wanting to mess with it much, than that will probably be the easiest bet since it is more plug and play than the MHD. |
12-04-2015, 09:49 AM | #15 |
Rep 261
I'd go with mhd backend flash stacked with jb4. I'm using mhd through my samsung note 4 and have a jb4.
With mhd you can back up your original ecu, change maps, read codes, reset adaptations and log all from your phone. |
12-04-2015, 10:04 AM | #18 |
Rep 261
12-04-2015, 10:36 AM | #19 |
Rep 1,040
I think Cobb is being pushed out of relevance on the N54 platform at this point. The price is double a JB4 and still hundreds more than both JB4 and MHD combined. MHD is more robust than Cobb. JB4 is still evolving with all of the new modding options and you can load free back end flashes through MHD designed to run with JB4, stack MHD flash and use JB4 to control boost, or just run custom flash maps with no JB4.
12-04-2015, 10:50 AM | #20 | |
Rep 261
12-04-2015, 11:17 AM | #21 |
Rep 554
Drives: 2013 335is E93 6MT
I'd hurry and sell the Cobb asap. The prices are slowly spiraling downward as more and more people realize it doesn't offer anything more than MHD, and in going forward offers less. Meaning if you already have an Android phone, the actual intrinsic value of a Cobb at this point should be less than the cost of the MHD flasher and monitor modules with an OTS map, plus the DCAN and OTG cables, which is ~$265 total.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
12-04-2015, 11:38 AM | #22 |
Rep 305
JB4 stacked with the MHD backend flash is great. Safer than just the JB4 alone, and you can take advantage of all the features of the JB4. (gauge hijacking, map switching, etc.)
