06-22-2015, 10:31 AM | #1 |
Rep 134
TPMS (mostly) questions
I'm coming up on tire rotation time (just shy of 4000 miles, maybe I should've done it already) on my xDrive, and it's got me wondering about a couple of things regarding TPMS.
1) I'm running 33f/38r for pressure as directed, and I see that matches up on iDrive pressure/temp display showing lower pressure in the front tires than the rears. When I rotate fronts to rear and rears to opposite front, do I have to do something so that the iDrive display matches up the correct corner with the wheel I've just put there? 2) I'm considering a set of aftermarket wheels. I've leased my car and I figure I can have a set of summer wheels with MPSS on them and probably have a small enough amount of miles on the OEM wheels/tires that I won't have to buy a pricey set of RFT's before turn-in, so I get the best of both worlds with only a bit more cash outlay. If I get a second set of wheels, I'd get a second set of TPMS sensors. What will I have to do to get the car to read these? In previous TPMS'd vehicles I'd have to go get the TPMS system wheel ID's reprogrammed every time I'd do a seasonal wheel swap. I'm hoping that TPMS reset in iDrive will take care of this stuff, is that the case? |
06-22-2015, 11:46 AM | #2 | |
1406
Rep 5,262
2)Just reset tpms on idrive |
06-22-2015, 12:09 PM | #3 |
Rep 134
So the car just figures out on its own that the front wheels are now in the back, and vice versa? Nice.
Any idea if the aftermarket sensors TireRack (and I suppose others) sells support temperature as well as pressure, like the OEM ones? |
06-22-2015, 12:46 PM | #4 | |
1406
Rep 5,262
Yes they do... i have the tirerack ones on a separate wheel set and it shows temp too |
