06-03-2015, 10:10 AM | #1 |
Rep 132
Squeak front right wheel area, need some more advice.
I have what sounds like a plastic type squeak on our new M235. The sound increased in frequency and a bit louder with increased rotational speed. Stock suspension OEM 624M wheels. I took the wheel off nothing appears to be rubbing and no stones etc in the tire. It almost sounds like the squeak on a basketball court with shoes.
If you can have a listen at the 7 second and 11 second mark. I will take the wheel off again and have a look but not sure where else to lool. Also it only happens when the wheel is straight and not on turning. I read a lot about some suspension related squeak on turning. Audio Clip. https://clyp.it/udmhtdac Thanks |
06-03-2015, 10:18 AM | #2 |
3079
Rep 5,578
Turn the wheel tire assembly with the engine off. Then turn brake disc by hand engine off. If noise only happens w/engine running could be ABS - example guess.
06-03-2015, 12:47 PM | #4 |
Rep 132
06-03-2015, 06:41 PM | #5 |
Rep 132
Ok I tested this, hoisted the car up, with the car off I spun the wheel no clicking noise. So you think it could be related to the ABS?
06-09-2015, 07:07 AM | #7 |
Rep 132
The squeak ended up being related to the manufacturer ticker that was left inside the tire, it was near the bead of the tire. Took a few hours to get to the root of the problem. They took apart the breaks first before moving onto dismounting the the tire. Thanks for all the help.
06-09-2015, 08:10 AM | #8 |
3079
Rep 5,578
STICKER ?
That's funny. But reassembling the brakes was the right thing to do. I once had a similar complaint on a Mercedes and the dealer wouldn't pull the pads to check - I did the work and it was a misaligned pad. |
