UPDATED: Milltek didn't work for 335xi coupe
01-25-2008, 04:39 PM | #1 |
Moderator
675
Rep 4,737
The transfer case (red circle) is in the way. stock pipes give enough clearance (335i shown below), but Milltek doesn't (2nd picture)...
Do you guys think I can use the stock front section and connect it to the Milltek x-pipe? Last edited by rzm3; 02-08-2008 at 05:11 PM.. |
01-25-2008, 04:53 PM | #2 |
152
Rep 5,501
That sucks. Beautiful car.
2007 E92 Montego Blue 335i
01-27-2008, 12:11 AM | #5 |
Rep 883
That looks like enough clearance to me. Is it touching when everything is installed? The picture makes it look like there's at least a few inches of clearance.
If you have a quality exhaust shop near by, they should be able to make it fit.
'12 E92 M3 | 6MT | ZCP
01-27-2008, 08:52 AM | #6 |
442
Rep 18,331
A qualified installer should be able to heat the pipe up and bent it ever so slightly to make it fit!!! I seen it done a thousand times where they heat it up till its bright orange and bend it...
01-28-2008, 10:23 AM | #7 |
Rep 66
eisenmann SR pipes will work just fine for all non-cab models (i.ci,xi)
For those who have Cab models, you can simply modifiy the pipes to clear the rear braces - making humps on pipes will work just fine. |
01-28-2008, 10:30 AM | #8 |
Modaholic
88
Rep 1,705
How much did you pay for installation with the modifications? I was thinking about the Milltek for my E90, but I never got an answer as to whether it would fit!
Euro Delivery - April 2007
