11-18-2014, 06:58 AM | #1 |
Rep 1,252
Dinmann Sideskirt extension/RW frontlip
Hi i just recieved my dinmann Sideskirts and waiting for my RWcarbon varis style front lip
took some photos before attempting to install probably i'll have some spare time this weekend to install , do you recommend a particullar way or have some advise am happy to hear. it came with 14x nuts( not sure what its called i hope am not wrong) and 14x screw. enjoy! with flash overall view gift Update: 11/26/2014 just received my RWcarbon front lip! Am getting frontlip + sideskirts film-protected, then tomorrow will install front lip and hopefully if have time to install sideskirts!! _________________ Update: 11/29/2014____________________________________ Morning pics!
Docrace 6266
11-18-2014, 10:29 AM | #2 |
Rep 826
Drives: G80 M3 & G87 M2
Subscribed for installed pictures
Carbon fiber for the everyday driver: rwcarbon.com 3941 E La Palma Ave Anaheim CA, 92870 info@rwcarbon.com / (714) 328-4406 Instagram/Tiktok/Facebook: @rwcarbon |
11-18-2014, 10:45 AM | #3 |
2717
Rep 3,429
Very nice. Post pics after install.
No one can verify if F30 side blades fit F32 yet. Only option there is still OEM matte black blades for the F82, which do fit. |
11-18-2014, 10:59 AM | #4 | |
Pace Car Driver
1555
Rep 3,166
OP: http://www.uline.com/Product/Detail/...Q&gclsrc=aw.ds |
11-18-2014, 11:33 AM | #5 | |
2717
Rep 3,429
11-18-2014, 01:16 PM | #6 | |
Rep 1,252
Docrace 6266
11-18-2014, 01:51 PM | #7 | |
Pace Car Driver
1555
Rep 3,166
Ideally I'd like to use the same material for a homemade front splitter so that the material matches front and side. I have no use for tacked-on raw carbon fiber on our car. That's my dream anyway. If I have time I'll get you a pic of what I mean. Would measurements help you FC4? |
11-18-2014, 01:53 PM | #8 | |
Pace Car Driver
1555
Rep 3,166
With the tape and screws, you could probably use half as many screws thus less holes in your rocker panels.......OEm uses both tape and screws AND betalink. OP, have you considered using OEM hardware to install your pieces? Have you checked out the OEM installation instructions? http://f80.bimmerpost.com/forums/att...3&d=1414071445 Genuine Factory BMW OEM Trunk lid trim rivet Label EXPANDING RIVET [ 2 ] Part Number 07149193301 Online Price $0.37 Last edited by G30 B58; 11-18-2014 at 02:06 PM.. |
11-19-2014, 03:12 AM | #9 | |
Rep 1,252
even if Screws are holding alone 3M tape will help and will make an *Washer* effect to keep both surfaces abit away from each other and still tight. i have seen the intstruction which uses like 17 screws each side . won't drill 17 hole into it sorry!BMW!!
Docrace 6266
11-19-2014, 07:18 AM | #10 |
Rep 1,252
i removed ///M door side sills but can't find a screw or anything that holds up the sideskirts :S anyone converted from (X) to Msport got idea how to remove the sideskirts?
Docrace 6266
11-19-2014, 05:13 PM | #11 |
Pace Car Driver
1555
Rep 3,166
Why do you wanna remove the rocker panels? So you can use the nuts provided? The OEM side blades / skirts instructions don't remove them.
Just sayin'. |
11-19-2014, 11:09 PM | #12 |
Rep 1,252
yeah but how am i supposed to drill with it when its on the car :S
Docrace 6266
11-20-2014, 10:02 AM | #13 |
Pace Car Driver
1555
Rep 3,166
OK, the OEM side splitters come pre-drilled so you hold them up there, mark your rocker panel then drill on the marks. Then use the OEM expanding plastic rivets.
You case is a little bit different but still doable w/o removing the rocker panels. |
11-20-2014, 01:44 PM | #14 |
2717
Rep 3,429
So did you install the M4 side blades yet?
11-20-2014, 07:06 PM | #16 |
Pace Car Driver
1555
Rep 3,166
11-28-2014, 05:06 PM | #20 |
Rep 826
Looks killer! Can't wait to see more
11-29-2014, 05:43 PM | #22 |
Rep 826
Looks great! Thanks for the pictures
