2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY: JB4 Stage 2 N55 Harness A
      10-27-2014, 12:34 AM   #1
GG.
Drives: 2011 F10 535i
Hi, Can someone explain and post a few pics for me about installing the JB4? i did not really understand the guide provided by BMS.
Thanks,
Andrew
      10-27-2014, 12:39 PM   #2
Mr Clean
Mr Clean's Avatar
Drives: F10
I have harness B but Im sure the rest of the install is the same (attaching the black wire to ground, red to power and the other two to the CAN wires). What do you need help with?
Follow me on Instagram: MrcleanF10
      10-27-2014, 06:47 PM   #3
GG.
I dont really know yet cause im still waiting for the jb4 to arrive. but i dont really understand the guide made by bms. I'm just wondering if someone made some video install guide for it. I'll get back to you if i need more help. thanks anyway bro, appreciate it.
      10-27-2014, 08:20 PM   #4
Mr Clean
Mr Clean's Avatar
Drives: F10
Yeah man no worries. I might do an install video just because there are no sources for further clarification (other than contacting BMS). I had a shop try to install it and fail and at that point I just decided to do it myself. It wasn't hard at all, just double and triple check everything and you'd be alright. Make sure to get the usb cable because it is the only way you can change maps and read/clear codes. Let me know when your ready, you can post here or Pm me.
      12-02-2014, 07:27 PM   #5
J BONE
The Boss
J BONE's Avatar
Drives: %E2%80%9816 F15 X6
2008 E92 335xi  [9.00]
Any updates would be appreciated. Agree with the OP, the info from BMS isn't that great. Only reason I haven't pulled the trigger is the install.
2016 F16 X6
2015 F15 X5- Retired
2013 F10 535xi- Retired
2011 E92 M3- Retired
2011 E90 335- Retired
2008 E92 335- Retired
      08-05-2015, 03:04 AM   #6
AWF10
Drives: 2011 535i
I'm trying to install stage 2 jb4. Directions say to install all 3 connectors of wiring harness except the purple MAF connector? Installed it and don't feel like I've gained 60-80hp but engine runs fine.
Tags
bms, bmw, diy, f10, jb4
5post
