325i N53 Strange Sound
10-17-2014, 07:12 AM | #1 |
Rep 114
Hi all,
I am aware that these engines are 'clicky' or 'tappy' due to the DI injectors, and I just wanted to check that the sound below is what people are referring to when they mention this? Thanks. |
10-17-2014, 09:15 AM | #3 |
Rep 286
+1 mine sounds exactly the same as that as well. if u get a higher pitched metal clang litterely sounds like metal on metal then thats the issue most people have addressed. however the sound in the video doesn't sound like anythings wrong.
10-17-2014, 09:30 AM | #4 | |
Rep 114
More curious than anything. Thanks guys |
10-17-2014, 12:45 PM | #7 |
624
Rep 3,200
Drives: E92 325i MSport Coupe
Normal. It does seem to get quieter with age/miles...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
01-04-2016, 04:57 PM | #8 | |
Rep 681
Reason for asking is I opened a post in the nasp section but I think there may be more n53 folks here. Sorry to cross post! Perhaps it a mod could move it to UK or UK technical please? http://www.e90post.com/forums/showthread.php?t=1208295 Last edited by Dormermike; 01-04-2016 at 05:21 PM.. |
01-04-2016, 06:22 PM | #9 |
12
Rep 405
My 325i m sport sounds exactly ,it's because when the engine is in idle it's using hardly any fuel,I only found this out after speaking to an expert on here,so it's nothing to worry about.
01-05-2016, 03:59 AM | #11 |
624
Rep 3,200
Both. And the slight drop in rpm when you open the oil filler is normal too. These engines run with a slight vacuum in the crankcase.
01-05-2016, 06:04 AM | #13 |
12
Rep 405
Yeah both bud,I agree with phil,I was nervous like you at first as thought it was a little noisy but the good guys on here put my mind at rest :-)
01-05-2016, 02:42 PM | #15 |
12
Rep 405
01-05-2016, 03:44 PM | #16 |
Rep 681
Congrats on the baby!
I raised both of my young uns with a e46 saloon, even went to France with a pram in the boot and a roofbox. Was a bit of a squeeze Good luck findin a new car. |
01-08-2016, 10:26 AM | #17 |
Rep 4
I have a 325i lic with the N53 engine. When I take the oil refiller cap off, then engines starts immidiately to run very very rough. Almost goes out.
Is this normal? |
01-08-2016, 10:42 AM | #18 |
624
Rep 3,200
Yes. See post #11...
