      10-14-2014, 04:57 PM   #1
leo037
leo037's Avatar
Drives: E92 335i / E46 M3
E46 M3 Mysterious Misfire! Any ideas?
Good day my fellow BMW enthusiasts,
I've been dealing with a misfire issue that is giving me headaches as I'm unable to find out the reason why it is causing the misfire. Any help here would be much appreciated!
So I've done most of the basic mechanical fixes include:
-Plugs
-Coils
-Injectors flush
-Compression test
-Fuel filter
-Fuel system cleaner x 2 (on two tanks)
-Oil cover gaskets
After the above I figured it was an electrical problem, and therefore did:
-Wiring test
-ECU reflash
Results still the same, "Cylinder 6 misfire". The ONLY temporary fix that I've discovered is resetting the ECU, that will give me 15kms of normal driving until the misfire comes back.
Any suggestions?
Thanks in advance!
-Leo
Honda Prelude 5th Gen | Acura CL Type-S | Nissan 350z Roadster | BMW E92 335i | BMW E46 M3
      10-16-2014, 08:49 PM   #2
edwinm3
edwinm3's Avatar
Drives: F82
check your crankshaft sensor, when it's going bad it causes misfires and you'll never know that's the cause.
Grigio Telesto M4, 6MT.
Coyote 5.0 F-150
991 GT3
