WTB: CCC/CIC I-Drive Connector Pigtails for my retrofit!!
07-03-2014, 10:01 AM | #1 |
Nomore
149
Rep 793
So im doing an idrive retrofit in my e92 335i. Right now it does not have navigation. So i already bought a CCC idrive system. But i need some connectors because it didnt come with all of them. CCC Idrive=2006-2008 CIC Idrive =2009-2011/12 So i need connector pig tails.( the connector cut off the harness with a few inches of wire left, so i can make new connections) So far i need: CCC idrive screen- power connector. Big black 2 row connector with a grey locking arm CCC headunit fan connector- small 3 or pin connector. Plugs into the fan on the back of the headunit fan. CCC/CIC idrive knob connector- small 4 pin connector. Connects to bottom of knob. Need 2. One for the back of the head unit and one for the knob itself. Same on both sides i believe. Also need a few other parts if you have: -Climate control trim from a navigation equipped car. -Center console -aluminum trim- with CIC or CCC Idrive knob cutout (will also -consider other interior trim styles(piano black,etc)) If anyone knows the part numbers for any of these connectors that would be great also! |
07-03-2014, 09:13 PM | #2 |
295
Rep 2,203
I'm kinda in the same boat with my retrofit as well..
I bought these pins to make my own harnesses... 61131393704. Universal socket - iDrive controller - 61138380696.. Go to your nearest dealer they should have them. I may just have my Controller itself from a dealer online, doesn't seem too pricey compared to what people are trying to sell for their used ones. Then I bought 4 conductor wiring from superbrightleds.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
07-03-2014, 09:41 PM | #3 | |
Nomore
149
Rep 793
So those two part numbers are for the idrive knob connectors? Are you doing a full idrive retrofit or a CCC to CIC retrofit? Would happen to know the part number for the idrive screen (cid) power connector? I found new idrive knobs on ecstuning. 200$ for a new cic controller with chrome knob. Last edited by AWDBooSTIn90; 07-03-2014 at 09:48 PM.. |
07-03-2014, 09:46 PM | #4 | |
41
Rep 692
07-03-2014, 11:34 PM | #5 | ||
295
Rep 2,203
