F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > On-track - F30 328i vs E36 M3 vs E46 M5
ARMA SPEED
      06-25-2014, 11:50 PM   #1
ronin951
ronin951's Avatar
44
Drives: 2013 328i M-Sport
So I took my 'new' e36 out for its first track weekend this past weekend and wanted to do a little comparison between my two cars as I frequent this track (Sebring) a lot. The idea was to take my two all-time best laps and overlay them to see if there were any areas of the track that one may excel over the other.
It turns out my for my pre-fastest E36 lap I was following an E46 M3. I just realized the F10 was also in the F30 clip. This is the same owner of the E46. All cars are pretty much stock, though I think the E46 has a little more additional HP over stock. Exhaust and a flash IIRC. However, he has 190k on the engine. My F30 specs are in my sig. The E36 is stock with camber plates, Kosei's, and 130k on the engine.
Verdict
My M3 seems to be able to carry more speed through the corners. I'm not sure if I should be surprised by this, but it is what it is. From a driving experience I think the LSD makes a huge difference on corner exit. I've always had problems getting power down with the F30.
The other thing that struck me was how much better I felt the F30 rotated. Maybe I just feel it more because it's a bigger car, but I just couldn't get the M3 to rotate around the hairpin like I'm used to in the F30. One caveat is I do have a ton of more seat time in the F30.
Speaking of seat time. My e36 times continued to increase as the weekend went on. I think it was a matter of getting more confident with the car. OTOH, with the F30 my times continue to improve but the slope has decreased after 6 days on this track. For example, my first session average was 5 seconds off my previous F30 session. By the end of the weekend things were about equal. I guess time will tell.
In summary..
F10 Toasts all (duh)
F30 hangs with e36
E36 beats F30, but not by much. Traffic was probably a factor too
E46 toasts E36 & F30
A side note is I'll readily admit the E46/F10 driver is faster than I. However, not enough to dust my F30 like he did Also, this should be considered a 'same car same driver' comparison for F30/E36. The E46 business is more for show. Mainly demonstrating the HP difference in the straights.
[u2b]http://youtu.be/3pCjdQ2NihQ[/u2b]
2013 EBII 328i M-Sport 6MT, M-Performance Brakes, M-Performance Suspension, APEX Arc-8 18 x 8.5 square, Pilot SS
1999 EB1 M3 - Bilstein PSS9, Vorshlag Camber Plates, Kosei K1, ZII Star Spec, PFC, gallon of distilled water.
      06-26-2014, 10:15 AM   #2
SergioK
Drives: F30 328i
What tires are the cars running? There's a world of difference just with tires. My (F30)328i had the same lap times as a (F30)335i, because I was on Michelin Pilot Supersport tires vs the 335i's runflats.
Turn in on a 328i will feel better (vs an E36/46) since the engine weights less and it's tucked further back into the chassis. What engine was in the F10? Surprisingly you mentioned lack of LSD on the F30 though I've never seemed to have an issue with wheelspin or not being able to get the power down. Dunno.
      06-27-2014, 01:40 PM   #3
ronin951
ronin951's Avatar
44
F10 - PSS
F30 - PSS
E36 - NT05
E46 - ? (street)
I've had issues sometimes with power down after some hard trail braking on a tight right hander. Slowing down and delaying getting on the throttle a few ms does seem to resolve it. I do have coilovers on the E36, so the stiffer springs may be allowing the car to recover faster/not travel as much.
I will say I missed my brakes on the F30. They can take a beating and keep on giving. OTOH, the e36 floaters with XP8 compound left a lot to be desired mid session.
f30post
