02-01-2021, 08:08 AM | #177 |
Rep 1,189
02-01-2021, 11:39 AM | #178 |
6566
Rep 2,310
Drives: 9Y0 Cayenne S
Keep going!
02-03-2021, 01:25 PM | #179 |
Rep 1,189
If you insist.
Flocked its box.... Untitled by Nick Wood, on Flickr Then it was time to install its face. We did a little polish/clean up on its snoot. Untitled by Nick Wood, on Flickr The nose job. Untitled by Nick Wood, on Flickr Add some eyes. Untitled by Nick Wood, on Flickr And a shark is born. Untitled by Nick Wood, on Flickr Sorry that was a little goofy but its a slow day at work and it was fun to kill a little time. I cant believe just how far is as come and how close we are to the finish line. Untitled by Nick Wood, on Flickr |
10
happyjack1657.00 P111572.00 tracer bullet2419.00 chassis6565.50 stein_325i25084.50 Stumpel37.00 wdb4732.00 Tom's 135i27.00 spazzyfry1234361.00 larryn2147.50 |
02-03-2021, 01:33 PM | #180 |
6566
Rep 2,310
Looks great. How did you do the flocking? Spray or fabric+adhesive? Was a primer needed?
02-09-2021, 09:36 AM | #182 |
Rep 1,189
Again, another small e9 update. We sprayed some undercoating in the fender wells.
Untitled by Nick Wood, on Flickr There is also a random hole in the both the front wheel wells. Its formed when the fender is seamed in over the front structure of the car, it leaves a fist sized hole in the wheel well that turns out to be a moisture trap. This is a before photo but it was also treated and undercoated to hopefully stop rust. We used a boroscope to check it out and it looked surprisingly clean. Untitled by Nick Wood, on Flickr But the best update so far, possibly even better than the paint job. Those awful gold wheels have been finally removed. Untitled by Nick Wood, on Flickr |
02-09-2021, 09:00 PM | #183 |
6566
Rep 2,310
The paint in the lighting of the last photo looks great.
MPOWER52664753.00 |
02-09-2021, 09:58 PM | #184 |
Rep 641
Love the color choice and the progress! Can’t wait to see the end result!
MPOWER52664753.00 |
02-10-2021, 09:23 AM | #185 |
Rep 1,189
02-10-2021, 10:24 AM | #186 |
6566
Rep 2,310
Looks great. Is the tire to wheel lip clearance factory? I would leave it at the original ride height, if that's where it stands today. Did you replace springs or control arm bushings?
How does the side glass run up and down in the tracks? Looking good, hoping to see on the road/in the wild photos. |
02-10-2021, 01:48 PM | #188 | |
Rep 1,189
Im not sure what you mean about the windows. Since work is slow, and Im just getting really excited about the progress on the car, here is a super small update. My dad found some generic rubber boots and used them as a dust covers for the headlight connectors. Untitled by Nick Wood, on Flickr Untitled by Nick Wood, on Flickr Untitled by Nick Wood, on Flickr With the dust covers installed the headlights went back in and the front end is officially buttoned up. Untitled by Nick Wood, on Flickr The dip switch(high beams) was broken and they are extremely expensive. My engineer father took it apart and repaired and redesigned it a little to make it work. Untitled by Nick Wood, on Flickr The A/C vent covers were installed. Untitled by Nick Wood, on Flickr And the drivers seat, its almost ready to make the trip to my garage for final detailing. Untitled by Nick Wood, on Flickr |
02-10-2021, 04:14 PM | #189 |
6566
Rep 2,310
Nice pics.
I was asking about how smooth and easily the side glass rolls up and down in the tracks. Did you replace, clean or repair the window regulators? Control arm position when the bolts are torques affects ride height. If control arms are torqued in the “droop” position, the body will ride a bit high, even if standard OEM coil spring length and rate is used. Do you know the control arm positions when the bolts were torqued? |
02-11-2021, 01:30 PM | #190 | |
Rep 1,189
Nothing was toque while it was drooping. It has been on the lift for a few days so Im sure it will settle down a little but even when settled there is a good bit of wheel gap. For now we are just going to get it to the show in May and maybe lower it a hair after that. |
02-15-2021, 07:53 AM | #191 |
Rep 1,189
Super small update, as usual. We have had nothing but crappy raining days this week but we got the e9 moved over to my house Friday night in between storms.
Untitled by Nick Wood, on Flickr The plan will be to work on it here and there over the next couple weeks as the twins will let me. I need to wet sand the hood, go over the whole car with a light compound, polish, and seal the paint. I may also steam the engine bay and any other little detail stuff I find. I did my first repair Friday night by fixing the handle on the ebrake with a 3/4" deep well socket and a rubber mallet. Untitled by Nick Wood, on Flickr I will certainly share more as I get some work done this week. |
02-17-2021, 08:23 AM | #192 |
Rep 1,189
I actually got some garage time in last night. I finally finished wet sanding(hopefully) on this car. This was about midway through the process. I ended up doing 2 passes with Megs 101 and one pass of Jescar compound. This was after the first pass of Megs.
Untitled by Nick Wood, on Flickr I am hoping to pull it out of the garage this evening, blow off all the dust, wipe it down and give it a good looking over before the sun sets. Then hopefully tape it off for polishing after the kiddos go to bed. |
02-22-2021, 08:16 AM | #193 |
Rep 1,189
I finished the polish work over the weekend. Compounded the hood fully.
Untitled by Nick Wood, on Flickr And gave the rest of the car a full polish. Untitled by Nick Wood, on Flickr And pulled it out in to the sun to give it a once over. Its looking pretty damn good. Untitled by Nick Wood, on Flickr Ill get the sealant and wax on this week and get it back to my dads shop next weekend. The bumpers are ready to go on and most of the trim can be installed. I am hoping its about 2-3 weeks out from a first drive. |
02-24-2021, 08:15 AM | #194 |
Rep 1,189
More small updates on the e9. Monday night I put a coat of Jescar Powerlock sealant on and installed the hub caps.
Untitled by Nick Wood, on Flickr My dad is knocking out little projects while I have car, he painted the rocker covers. Untitled by Nick Wood, on Flickr He also picked up the rear bumper from the chrome shop. The front bumper was not included with the car, so we sourced one shortly after buying the car. It was in much better shape than the front so we had this one chromed to match. It came out very nice. Untitled by Nick Wood, on Flickr He also polished the front bumper using the worlds oldest can of Turtle wax chrome polish. No joke, I think that can is 30 years old.. Untitled by Nick Wood, on Flickr Last night I put the first coat of 845 on. This might be the only chemical that rivals Hoppes 9, I would wear a Collinite 845 colone. Untitled by Nick Wood, on Flickr I also cleaned and dressed two of the tires and started cleaning the windows, but I didn't get pics. |
03-08-2021, 07:59 AM | #196 |
Rep 1,189
Not a huge update but we are kinda waiting on some small parts to show up before we can put the bumpers on. Last week, the car went back to my dads shop since I was done with the paint. We then installed the repainted rocker covers.
Untitled by Nick Wood, on Flickr Cleaned up the strips on the front bumper that the rubber attaches to. Untitled by Nick Wood, on Flickr Installed the gills with the black vinyl underneath this time. Untitled by Nick Wood, on Flickr And put on some of the trim. Untitled by Nick Wood, on Flickr Untitled by Nick Wood, on Flickr And finally cleaned up the rear license plate lights before installing them in the rear bumper. Untitled by Nick Wood, on Flickr We are waiting on some stripper so we can finish stripping the trim and polishing it and some rubber parts for the bumper. I am thinking its still about 3-4 weeks away from the first drive but I am hoping it will be done sooner. |
03-08-2021, 09:51 AM | #197 |
6566
Rep 2,310
Looking good!
