Technical Sections Coding / Tuning / Audio-Video / Electronics
      03-31-2020, 12:59 PM   #1
Moderator
Moderator
48
Drives:
Enabling shift lights for 6MT manual transmission
Full credit goes to p0lar for this writeup.
The E46 M3 is equipped with a sequence of 7 multi-function amber lights that tail the tachometer in a radial pattern from 4500 RPM to 7500 RPM. While the car is warming up, these lights are ordinarily used to indicate engine oil temperature; however, once the oil has reached the monitoring threshold, they become dormant, except on the SMG-equipped cars, where they become shift indicator lights.
The 'shift lights' feature on the E46 M3 was not enabled for manual-transmission cars from the factory, but was enabled for SMG-equipped cars by default. Though it's been explained elsewhere in great detail, this thread is simply the placeholder for the elements required to make the changes for 6MT-equipped cars, as well as a comprehensive list of the shift light location in all MSS54/MSS54HP DME variants.
As usual, the first step is to identify the program version of DME. Once the DME's version has been identified, reference the following table and examine the byte at the proper offset.
Name:  Screen Shot 2020-03-31 at 10.56.56 AM.png
You should see a string that looks as follows:
C8 1E 06 00 DA FE
Alternately, you can also search the partial binary for 'C8 1E 06 00'.
----- BEHAVIOUR MODIFICATION -----
If you would like the shift light pattern to illuminate regardless of the sport mode setting, set the byte at the proper offset to '01' as follows:
C8 1E 06 01 DA FE
If you would only like the shift light pattern to illuminate while in sport mode, set the byte to '02':
C8 1E 06 02 DA FE
----- ERRATA -----
The shift light display will exhibit erratic behaviour when lowering the rev limits in neutral (either for "flat-foot shifting" or for 6MT "launch control" and may trigger on a shift regardless of in-gear RPM. There is no known workaround to date.
      08-24-2020, 01:48 PM   #2
ms_logging
Drives: e46 M3. e46 2.8 Turbo
good day. i am new here. i am interested about is there any way to enable shift lights without using clutch switch ? or maybe somehow it can be used some Ground to switch to do that job if original switch is unavailable/missing.? thanks
      09-01-2020, 10:26 AM   #3
Mr. 5
Modder Raider
Mr. 5's Avatar
Scotland
755
Drives: M3
2007 e90 335i  [8.00]
I just did a manual swap, and I enabled the manual shift lights using Martyn's tool and they are still not working.
I even verified this string...
C8 1E 06 01 DA FE
And I do have it set to 01 and I still don't have the lights.
Strange.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD
Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM
