      09-17-2020, 02:21 PM   #1
msdss
msdss's Avatar
Drives: Alpine White 2020 BMW M2C
Has anyone ever replaced their hood badge?
I just replaced the hood badge on my E46. I've verified via realoem, and getbmwparts that I have the correct part. I'm compared the part number stamped on the inside of the old badge, with the new badge. They match.
The only visual difference I can see, is that the original badge has a chrome back, and the new badge has a black plastic back. So I'm guessing at some point they changed it.
Anyway... The issue I'm having is that I pressed the new badge into the hood using new grommets, and the badge dooesn't seem to sit flush. The left and right sides are full flush against the hood, but the top and bottom of the badge are lifted very slightly.
The result is that if you touch the top of bottom the badge actually moves and it kind of see-saws. I don't know how to fix this. I'm using all the right parts to the best of my knowledge...
Has anyone experienced this before? Have any advice for me?
For reference, the part # was 51148132375.
      09-26-2020, 04:28 PM   #2
cncmastr
cncmastr's Avatar
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [10.00]
Pics?
      09-26-2020, 04:33 PM   #3
msdss
msdss's Avatar
Originally Posted by cncmastr View Post
Pics?
[IMG]undefined[/IMG]
it's hard to capture with a photo. the badge does not sit dead center in the recess. it's slightly higher than center. the pegs it inserts into are extremely tight and do not allow for any horizontal or lateral play.
I would prefer the old shitty, peeling, faded badge that fits, to this brand new awful.
      10-16-2020, 08:49 AM   #4
JJakes
Drives: 2003 M3 Vert
I had to replace mine - my car came with all black and white emblems. I didin't have this problem but I would reach out to the place you bought the part from and let them know it's not working properly. It may be the part and not anything yoú're doing wrong. As you said, there isn't much room for adjusting the position and AFAIK it should just pop in there and sit flush.
msdss497.50
      10-31-2020, 08:17 PM   #5
InnerBlueSkies
InnerBlueSkies's Avatar
1093
Drives: 2008 E90 M3
I had the same issue with my hood emblem and the sun and heat eventually resulted in it sitting flush.
