E46 M3 Marketplace Vendors Products
      05-08-2020, 03:26 PM   #1
Expert@ApexWheels
Expert@ApexWheels's Avatar
3562
Drives: M3
APEX Wheels | Classic Forged Line
Questions?
Call: 925-245-0773
Email: expert@apexraceparts.com
Web: www.apexraceparts.com
Hours: M-F 9a-5p PST
ARC-8R & EC-7R
Everything you love about the original, now enhanced with all the added benefits of forged manufacturing.
➡︎ Significantly increased strength
➡︎ Improved brake clearance
➡︎ Paintless knurled beads
➡︎ New premium finishes
Order Now
ARC-8R / EC-7R
Available Finishes
Even More Strength
“Forged” doesn’t mean strong. Many forged wheels focus on weight reduction so much that they end up with the same load rating as cast wheels. Think all forged wheels are stronger than cast or flow formed? Think again. We've added up to 1,000 pounds of extra load capacity per vehicle compared to our flow formed line.
Learn more about why not all 'forged' wheels are strong.
Better Brake Clearance
The flow formed ARC-8 was our first design, so it features our older barrel profile with compromised brake clearance. Typical blank forgings (the starting point many other manufacturers use) can have even worse clearance than our original flow formed wheel. By developing our own proprietary new profiles and new dies, the 18" ARC-8R and EC-7R can clear Brembo 380mm kits and the 19" version can clear BMW 410mm carbon ceramics.
Learn more about why we had to create our own new forging dies to clear big brakes.
Paintless Knurled Beads
Not all knurling is created equal. To reduce unwanted tire spin as much as we could, we protected our knurling from paint to keep them sharp. We didn’t take the cheaper shortcut of painting over the bead area, which makes the knurling smoother and rounder. See and feel the difference.
Learn more about why our forged wheels have unpainted knurled beads.
New Premium Finishes
Our forged wheel line enabled us to release premium finishes we’ve always hoped for. Fully polished aluminum and hand brushed with tinted clear now join a wide range of painted finishes, with more to come. Our forged wheels not only deliver performance, but also provide distinctive new styling as well.
Tailored Fit, Right Off-The-Shelf
APEX is known for stocking a wide variety of chassis specific fitments to meet the needs of a very diverse enthusiast community. We’re releasing those same street, track and race proven fitments and more in our new forged line. New lower production requirements allow us to cater to even the most niche segments of the BMW market that may have previously been off limits.
Weight Optimized
We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a fully forged wheel with an ideal balance of strength and weight.
JWL & VIA - More Than Just a Stamp
Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX Classic Line forged wheels are tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our forged wheels exceed those ratings by almost 20%. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy.
Learn more about VIA and JWL
Additional Features
Hub Centric - All APEX BMW wheels with a 5x120mm bolt pattern are purpose built featuring a 72.56mm center bore. No centering rings required.
Center Caps - We don't charge extra for caps and we design our BMW wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps.
Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly.
TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
Lifetime Warranty
All our forged wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase.
APEX Wheel Replacement Program
Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our unique APEX Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices.
Order Now
ARC-8R / EC-7R
Fitment Guides
We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides.
APEX Forged Wheel Gallery
Wheel & Tire Packages
Shop Tires
For your convenience, wheel and tire packages are now available at APEX. Our knowledgeable BMW Product Experts hand pick some of the best compounds available from prominent brands like Michelin and Nitto, and we’ve priced them competitively.
All wheel and tire packages include free mounting and road force balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse.
Order Now
ARC-8R / EC-7R
Questions?
Call: 925-245-0773
      05-08-2020, 03:27 PM   #2
Expert@ApexWheels
3562
Drives: M3
Introducing the ARC-8R
Race Silver
Anthracite
Satin Black
Brushed Clear
Polished
Introducing the EC-7R
Race Silver
Anthracite
Satin Black
Brushed Clear
Polished
      09-10-2020, 05:30 PM   #3
Expert@ApexWheels
3562
Drives: M3
APEX Forged: Stronger than ever and ready to ship.
Our new forged offerings have significantly higher load ratings with over 1000 LBS of additional capacity for 4 wheels in an 18" diameter compared to our already strong flow-formed wheels! The increase in load rating allows these new wheels to better cope with the demands that sticky tires, heavy cars, and high downforce present.
This M3 is track-ready with our ARC-8Rs:
Specs:
18×10" ET25 ARC-8R Forged Wheels in Brushed Clear
275/35-18 Toyo Proxes R888R Tires
Stoptech 355mm BBK
MCS 2 Ways NR
GC Camber Plates
      10-16-2020, 06:18 PM   #4
Expert@ApexWheels
3562
Drives: M3
APEX End of Summer Sale ENDS TONIGHT AT MIDNIGHT!
All forged BMW wheels are on sale from now until October 16th.
Pick up your set before the season ends!
      11-06-2020, 02:40 PM   #5
Expert@ApexWheels
3562
Drives: M3
Polished and Brushed Clear finishes
Available only on the Forged ARC-8R and EC-7R
      12-07-2020, 03:51 PM   #6
Expert@ApexWheels
3562
Drives: M3
APEX Forged ARC-8R: Massive Brake Clearance
The ARC-8R addresses the biggest challenge we faced with the original flow-formed ARC-8: brake clearance. Thanks to new high-clearance forging blanks, 380mm brakes now fit behind the 18” version with plenty of breathing room.
      01-04-2021, 06:52 PM   #7
Expert@ApexWheels
3562
Drives: M3
The Fully Forged APEX EC-7R
Available in a wide range of finishes including Satin Black
      01-22-2021, 04:37 PM   #8
Expert@ApexWheels
3562
Drives: M3
The fully Forged ARC-8R
Unlike our Flow Formed wheels, the Fully Forged APEX ARC-8R and EC-7R are offered with a profile 2 medium concave design even in the higher offset sizes. This allows all chassis to experience the awesome look of concave wheels.
      02-05-2021, 04:18 PM   #9
Expert@ApexWheels
3562
Drives: M3
The Fully Forged EC-7R: More Brake Clearance Thank Any Other APEX Wheel
The APEX EC-7R improves brake clearance over the impressive amount offered by the Flow Formed EC-7. Forging allows us to reduce spoke thickness without compromising strength. As a result, the EC-7R has more brake clearance than any wheel we've ever made.
      03-11-2021, 07:01 PM   #10
Expert@ApexWheels
3562
Drives: M3
Lighter and Stronger
The Fully Forged EC-7R is significantly lighter and stronger than the Flow Formed EC-7. By implementing Finite Element Analysis (FEA) to eliminate excess material, the EC-7R was made even lighter without sacrificing strength.
      04-06-2021, 05:16 PM   #11
Expert@ApexWheels
3562
Drives: M3
The Fully Forged ARC-8R in Brushed Clear
The Fully Forged ARC-8R offers the same classic look as the original with a far higher load rating, improved brake clearance, a reinforced inner lip, and unpainted knurled beads.
      04-20-2021, 05:50 PM   #12
Expert@ApexWheels
3562
Drives: M3
Bigger, Tougher Inner Lip
The inner lip is the most vulnerable part of a wheel, because it has no spokes for support. By using forged 6061-T6 aluminum, and reinforcing this high-impact area with more material, we provide an extra layer of protection against track berms, potholes, and whatever else the road may throw at you.
      05-18-2021, 06:46 PM   #13
Expert@ApexWheels
3562
Drives: M3
BMW F80 M3 with EC-7R Wheels in Brushed Clear
F/R: 18x10" ET25 EC-7R with 275/35-18 Toyo R888R tires
      06-25-2021, 06:03 PM   #14
Expert@ApexWheels
3562
Drives: M3
The Fully Forged EC-7R in Polished Finish
F/R: 17x9.5" ET35 EC-7R with 245/40=18 Kuhmo Ecsta V720 tires
12mm spacers in front
      09-01-2021, 05:09 PM   #15
Expert@ApexWheels
3562
Drives: M3
The Fully Forged ARC-8R in Satin Black Finish
F/R: 18x10.5" ET22 ARC-8R Wheels with 275/35-18 Toyo R888R tires
18mm front spacer, 12mm rear spacer, and 90mm APEX stud kit
      10-07-2021, 02:33 PM   #16
Expert@ApexWheels
3562
Drives: M3
High load ratings, light weight, and damn good looks; The Fully Forged APEX EC-7R in Polished Finish
F/R: 18x10.5" ET22 EC-7R Wheels with 275/35-18 Toyo R888R Tires
JRZ RS one Coilovers and Rotora 380mm BBK
      12-08-2021, 01:19 PM   #17
Expert@ApexWheels
3562
Drives: M3
Paging BMW owners in the Bay area!
If you're interested in free professional photos of your car on brand new APEX wheels, we are looking for volunteers for testfiitting and photoshoots! Volunteers will get copies of the photos, a discount on a set of APEX wheels, and APEX goodies/swag. If you're interested in volunteering, please email us at info@apexraceparts.com with your contact information, location, and a photo of your car. All are welcome. Show us what you've got!
If you'd like to take an inside look at what these photoshoots involve, our good friend Blake made a video detailing the process of an 18" test fitment on his F82 M4 recently:
      01-13-2022, 03:58 PM   #18
Expert@ApexWheels
3562
Drives: M3
APEX Classic Forged Line EC-7R and ARC-8R are in stock and ready to ship in a variety of BMW specific fitments!
F: 18x9.5" ET22 w/ 255/40-18 Yokohama A052
R: 18x10.5" ET40 w/ 275/40-18 Yokohama A052
15mm front spacer and -3.5 degrees camber
      01-26-2022, 06:01 PM   #19
Expert@ApexWheels
3562
Drives: M3
APEX 2022 Build Season Sale!!
Save up to 20% off select Flow Formed and classic Forged wheels now through January 31st!
Click Here to Shop Now!!
      12-12-2022, 01:18 PM   #20
Expert@ApexWheels
3562
Drives: M3
Gear Up Now for the 2023 Track Season and Save BIG with our Year End Clearance Deals
Our year-end Clearance Sale starts today! If you didn't get new wheels for 2023 during Black Friday, now's the time.
Fair warning: when the inventory levels of certain fitments and finishes become too low, we will remove them from the sale, so... Place your order early to get the best selection.
Up to 20% Off Select Flow Formed Wheels
for BMW
30% Off All Remaining Classic Forged Wheels
Both ARC-8R and EC-7R
While Supplies Last – First Come, First Served
