      08-08-2016, 01:29 PM   #1
chronopete
chronopete's Avatar
Drives: 09 BMW 335xi Coupe & 01 Z3M
S54 issue - AVANOS1-late valve
Hello all,
As of few days ago, I'm a proud owner of a Black 2001 Z3M with the S54 engine. I found a great deal last week and couldn't resist myself I drove 750 miles from Virginia to Chicago, no issues. I plugged in the BT cable and unfortunately an issue was found - "AVANOS1-late valve". Can anyone chime in on this issue? Do I just need to adjust the valves? The motor runs strong, but it doesn't feel as fast as it should be - although I am a little biased because I also own a 400whp 335.
Any feedback would be much appreciated!
SOLD - Daily 09 335xi AT- VRSF 7" FMIC, VRSF DPs, VRSF DCI, VRSF Lower CP, ER upper CP, PTF Tune 93 octane, 19" Bayern, Pirellis, LUX H8 160.
2001 Z3M Roadster S54. Black on Black. Completely stock.
      08-09-2016, 06:03 PM   #2
chronopete
chronopete's Avatar
Anyone? The car has only 51k mi, the code # is 21.
      08-15-2016, 01:48 PM   #3
Mjosh
Drives: E46 M3
I think you should try the m3forum. You will get more answers there.
      08-15-2016, 10:29 PM   #4
chronopete
chronopete's Avatar
Good suggestion, thanks!
      07-24-2019, 09:48 AM   #5
saidsaba
Drives: e30 S54
Hello
This might be related with your Solenoid Pack
remove it and clean it with a magnet and brake clean, you should hear a click when its cleaned completely
