BIMMERPOST Universal Forums Site Related Announcements - Suggestions - Feedback - Questions
Closed Thread
      08-09-2011, 11:24 AM   #1
Lexington
Lexington's Avatar
53
Drives: 2008 135i Blue Water
Problems Posting
I have recently encountered a problem posting from my laptop. When I try to post I get an error message indicating essentially that the message portion needs to contain at least 1 character. I have typed several sentences. I've posted from my home laptop in the past.
I'm able to post from my work computer.
I sent an email to the web master but no response as of yet. Any ideas?
      08-09-2011, 12:16 PM   #2
southlight
Moderator / European Editor
southlight's Avatar
1552
Drives: X3M
I guess you're using IE9. If so, try to disable the WYSIWYG editor in your UserCP (Edit options --> Miscellaneous options --> change from enhanced editor to standard editor). Then you should be able to post again. Hope this helps until there's a fix for IE9.
Best regards,
south
Those forums...WHY NOT?
JOIN THE 6MT CLUB GROUP
IK6SPEED4496.00
      08-09-2011, 04:36 PM   #3
Lexington
Lexington's Avatar
53
Thanks. That fixed it.
      09-14-2011, 04:23 PM   #4
LEDZEP
LEDZEP's Avatar
419
Drives: 2009 E70 & 2011 F25
I have this same issue. Can you be more specific about the workaround? Is this an IE configuration change, or elsewhere in Control Panel?
I think it is bad luck to be superstitious
      09-14-2011, 05:22 PM   #5
southlight
southlight's Avatar
1552
Drives: X3M
It's in the UserCP on this site (first link to the right of the header image), and then follow the steps mentioned above. Let me know in case you didn't find it and I'll send you a PM.
Best regards,
south
      09-14-2011, 06:33 PM   #6
LEDZEP
LEDZEP's Avatar
419
Best regards,
south
Thanks! That did it, as does this quoted reply attest.
      08-25-2012, 02:01 PM   #7
Gogud
Drives:
can't reset edit prefs
I received the same 'at least 1 characters' message and came here after several attempts to post. When I disable WYSIWYG and save changes, the page switches over but no changes are actually saved. I tried the reset--nothing seems to be resetting. No matter how it is done, nothing changes...
      08-27-2012, 03:02 PM   #8
Gogud
Drives:
I logged in today and the settings are as I tried to set them. Posting is working fine for me now. Thanks.
      09-26-2012, 07:56 AM   #9
135
Australia
113
Drives: 135i
Hi,
For my first post, I am attempting to reply to an existing thread but am receiving the following error message:
you do not have permission to access this page. This could be due to one of several reasons:
1.Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
2.If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
My account is already validated. Is there anything else I need to do before replying to threads or creating my own new thread?
This was the only forum that I could successfully post a reply.
Thanks.
      09-26-2012, 08:03 AM   #10
135
Australia
113
Drives: 135i
It appears that I can now reply to threads after posting the above but I am still unable to create my own new thread.
Is anyone able to shed some light on this?
Thanks.
      09-26-2012, 08:13 AM   #11
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Thanks.
New users may no longer create new threads immediately. They must first make some posts (and then wait a day or so).
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
      09-26-2012, 08:38 AM   #12
135
Australia
113
Drives: 135i
Thanks for the reply. I saw the 5 post minimum applied to PMs but I didn't realise it applied to creating new threads.
Are there any forums that don't count for the number of posts?
      10-16-2012, 11:47 AM   #13
HIPSI
Drives: 08 135i
I've been having the same issue, made the changes... TEST post
08 135 Coupe SGM/Terra
15 Porsche Macan S- Family Hauler
22 C8 Corvette 3LT HTC
      10-23-2012, 02:09 PM   #14
Eagle1oh7
Eagle1oh7's Avatar
Drives: '11 328i Sedan
Well since I can't start a new thread, I've sent a message regarding upgrading my status over a week ago and I gotten no response yet. I still cannot send PMs and begin new threads. I have had well over the required posts needed in said timeframe and it still says the same message across the top of the page.
      11-03-2012, 06:46 PM   #15
CKau
Drives: G01 X3 Xdrive30i M sport
I'm a newbie and find I cannot start a thread, so I'm posting here just to say hi & hope this counts to my tally :-P
      11-06-2012, 07:48 PM   #16
CKau
Hi Jason. I'm a newbie. I'm getting a message saying 3 posts before I can start a new thread and to wait 48 hrs. It's been more than 48hrs since my 3rd post.
Is the limit actually 3 posts or 5 posts as someone else is saying in this thread?
thanks,
CK
      11-06-2012, 09:53 PM   #17
Jason
Administrator
Jason's Avatar
Drives: F80 M3
thanks,
CK
Look at your post count under your name. You only have 2 (counted) posts.
There are certain sections where posts don't count towards your post count, like the Off-Topic section.
      02-02-2013, 11:43 AM   #18
bertybassett
Drives: BMW 116 sports
I'm getting this too. Guess I will go add some comments to other peoples posts.
      03-01-2013, 12:12 AM   #19
328wagonxi
328wagonxi's Avatar
Drives: 328xi sports wagon
I'm having this same issue so I'm searching and posting on others to hopefully get my posts up
      04-11-2013, 08:59 PM   #20
boostfiend
Drives: 335i
I really think someone should either get a better anti-spamming software because 3 post+ 48 hrs by the time you want too figure out something you are a week away from an answer. For example I'm looking for a solid answer on what exactly is needed for M3 suspension on my 335i as they will be giving to me for free and I have too wait 3+ days too post in suspension when the m3 suspension is only available tomorrow no one wants too wait 3 days+ to get an answer when every search thread says you need complete different things for m3 suspension on a 335. 1 thread says you need m3 knuckles, brakes, sliders when that can't be right another says you don't need anything for the fronts and just need to get m3 camber plate for the rears the answers are so misguided the whole point of a forum is you signup to get answers to your questions not wait 1 week+ and miss your opportunity to get the info you need.
      06-10-2013, 01:47 AM   #21
darthcheng
Drives: N/A
I just listed something something for sale today. How can I edit the post? Thanks.
      10-11-2013, 09:57 AM   #22
atinybug
Drives: 07 e92 335i 6mt
I was unable to find a newbie introduction thread to get my 1 reply post in so I'm making this reply here.
Closed Thread
