Technical Sections Suspension / Brakes / Chassis
      01-10-2021, 05:35 PM   #1
msdss
msdss's Avatar
Drives: Alpine White 2020 BMW M2C
Does StopTech Drilled and Slotted Front Rotors for ZCP Cars?
I can easily find a set of StopTech drilled and slotted rotors for the rear, but I can only find regular street rotors for the front.
The fronts that ECS sells specifically state they will not work for cars with the ZCP package, and when I asked ECS, they said they didn't know and tried to get me to buy ECS branded rotors.
Does anyone know if StopTech makes them? It seems weird they would make slotted and drilled rotors for the rear, but not the fronts...
      01-12-2021, 11:23 PM   #2
to_riffic
to_riffic's Avatar
Drives: rwd
Wish I had a proper answer for you, but give Zeckhausen Racing or even Centricparts, directly, can yield you the most accurate responses you need. You can probably get them the part numbers and then shop around for better prices too.
~loud noises~
msdss497.50
      01-18-2021, 02:31 AM   #3
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Is there any particular reason you want to go with Stoptech over OEM? With FCP Euro's Lifetime Warranty, buy a fresh set once and never have to worry about paying for another set again.
https://www.fcpeuro.com/products/bmw...45#description
1995 E36 M3 | BMW CCA Club Racer - IP #34 | Gray / Blue / Orange | 261WHP | 2,700lbs
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
      01-18-2021, 12:47 PM   #4
msdss
msdss's Avatar
Mostly just cost. StopTech is generally near half the cost of OEM. I have no issue with OEM rotors, but StopTech tends to be a fair amount cheaper, and I have used them for a long time without any issues, so I trust their products.
