      10-17-2023, 03:42 PM   #1
hadidanee
hadidanee's Avatar
Drives: E90 M3
2004 E46 M3 6spd
OIL CHANGE 10w-60 BMW oil
Changed at 69,935 miles on September 13, 2013 w. TWS oil
Changed at 75,912 miles on April 12, 2014 w. TWS oil
Changed at 89,596 miles on May 27, 2015
Changed at 103,363 miles on January 8, 2016
Changed at 109,232 miles on July 22, 2016
Changed at 115,844 miles on August 20, 2019 BMW oil Castrol
Changed at 120,452 miles on November 15, 2020 10w60 BMW
Changed at 120,731 miles on January 1, 2023 when oil return line and camshaft sensor were replaced 10w60 BMW
VALVECOVER GASKET, PLUGS, COILPACK
Changed valve cover gasket at 121,300 miles on June, 2023 BMW
Changed all spark plugs at 121,300 miles on June, 2023 BMW
Changed all coil pack at 121,300 miles on June, 2023 BMW
-Also changed the spark plug tubes
BRAKE FLUID – DOT 4 ATE
Brake fluid flush at 87,232 miles on March 17, 2015
81-22-0-142-156
COOLING SYSTEM
Replaced thermostat at 65,021 miles on July 25, 2013
11-53-1-318-274
Replaced temperature sensor at 65,021 miles on July 25, 2013
13-62-1-433-076
11-53-1-318-402 O-ring
11-53-7-830-709 O-ring
Flushed and replaced coolant at 65,021 miles on July 25, 2013
82-14-1-467-704
Replaced temperature sensor at 81,380 miles on September 9, 2014
13-62-1-433-077
Replaced expansion tank at 112,872 miles on July 5, 2017
17-11-2-283-344
Replaced water pump at 115,844 miles on August 22, 2019
11-51-7-838-159 Saleri (OE) SAL-PA1297 FCPEuro
Water pump O-rings (2)
BMW
11-53-7-830-709 BMW
Replaced Thermostat at 115,844 miles on August 22, 2019
11-53-1-7-318-274 Borg-Warner (OEM) WAH-462180D FCPEuro
Flushed and replaced coolant at 115,844 miles on August 22, 2019
ANTIFREEZE – BMW antifreeze
82-14-1-467-704
VALVE ADJUSTMENT –
Adjusted at 109,309 miles on August 17, 2016
All valves within specs – Larchmere Imports
CLUTCH
Replaced at 103,363 miles on January 8, 2016
21-21-2-282-557S Clutch kit Sachs
21-51-1-223-302 Clutch Fork
21-51-1-223-328 Ball Pin
23-11-7-512-866 Guide Bush
11-62-7-830-668 Gasket Ring
18-30-1-317-898 Hex Nut
TRANSMISSION – RED LINE MTL
DIFFERENTIAL – RED LINE 75W-140
BRAKES
FRONT
Rotors, brake pads and sensors at 65,021 miles on July 25, 2013
SUPPLIED – HAWKE PADS
Front left caliper replaced at 87,232 miles on March 17, 2015
34-11-2-282-617
81-22-0-142-156
REAR
Rotors, brake pads and sensors at 75,912 miles on April 12, 2014
34-21-2-229-379 Rotors
34-21-6-790-071 Brake pads
34-35-2-229-780 Sensors
AIR FILTER
Replaced at 110,066 miles on September 21, 2016
MANN - C25114
June- 2023
VANOS
Exhaust and intake hub o-rings changed on August 27, 2016 at 109,666 miles – Beisan Seals
POWERSTEERING
Replaced Reservoir at 115,844 miles on August 20, 2019
32-41-6-851-217 ZF (OEM) FCPEuro
Changed ATF fluid at 115,844 miles on August 20, 2019
OXYGEN SENSOR
Pre-cat bank 1 replaced at 103,363 miles on January 8, 2016
11-78-1-743-994B Bosch
BELTS AND BELT TENSIONER, PULLEYS
Replaced accessory belt at 87,232 miles on March 17, 2015
11-28-7-837-898
Replaced AC belt at 87,232 miles on March 17, 2015
11-28-7-830-946
Replaced deflection pulley at 87,232 miles on March 17, 2015
11-28-7-841-228
Replaced adjusting pulley at 87,232 miles on March 17, 2015
11-28-1-748-131
BATTERY
Swapped with brand new battery from 03/325i on June 27, 2020 at 117,656 miles OEM BMW 61-21-2-353-808 80Ah
ALTERNATOR
Brand new (not remanufactured) Valeo OE alternator
12-31-7-831-436 VAL-439317 120 Amp on June 27, 2020 at 117,656 miles - FCP
ECU BLOWER MOTOR (CRICKET MOTOR)
Changed at 117,656 miles on June 27, 2020
Part # 12-90-7-570-074 - BMW
SUSPENSION
FRONT
Left front lower control arm replaced at 87,232 miles on March 17, 2015
31-12-2-229-453 LEMFORDER
Both sway bar links replaced at 109,684 miles on September 3, 2016
31356780847 – Meyle HD
REAR
Both springs replaced at 65,021 miles on July 25, 2013
33-53-2-283-135 Original BMW
Left rear spring broken – both replaced under warranty at 80,984 miles on August 25, 2014
33-53-2-283-136
Both rear shock mounts replaced at 109,684 miles on
September 3, 2016
3003359102HD – Meyle HD
TIRES (225/40-19 & 255/35-19)
Rear tires replaced at 89,596 miles on May 27, 2015
255/35ZR19Y Continental Extreme Contact DW
All four tires Michelin Pilot Sport 4S 225/40ZR 19Y , 255/35ZR 19Y replaced at 117,436 miles on May 20, 2021 Xtreme Performance
WHEELS
New VMR 710 19 x 8.5 & 19 x 9.5 installed on July 6, 2016 at 109,124 miles. No rashes present.
FUEL PUMP /w seal
Replaced fuel pump relay at 65,021 miles on July 25, 2013
61-35-7-892-976
WINDSHIELD WASHER PUMP
Replaced at 113,458 miles on September 10, 2017
67-12-8-362-154 - VDO-Siemens pump
61-66-7-006-063 – Strainer and grommet
HEADLIGHT WASHER PUMP
61-67-8-374-382 – Headlight washer pump grommet ONLY
MIRRORS
Outside passenger glass replaced at 109,300 miles on May 20, 2016
51-16-7-157-244
Inside rearview mirror replaced at 109,300 miles on May 20, 2016
51-16-7-126-522
MISCELANEOUS
New Floor mats at 109,300 miles on May 20, 2016
82-11-0-029-231
New M cover lower trim on the steering wheel at 109,300 miles on May 20, 2016
32-34-7-833-355
New trunk mat, June 2023
Muffler hanger passenger side replaced at 109,684 miles on
September 3, 2016
18-20-1-401-797 CRP
Rear mud flap coverings replaced at 113,458 miles on September 10, 2017.
51-71-8-244-045 - LEFT
51-71-8-244-046 - RIGHT
Constant pressure valve, oil return line, camshaft position sensor replaced at 120,731 January 2, 2023
Replaced the headlight lenses and seals, June 2023, BMW
RECALLS
Front driver side airbag replaced at 110,669 miles on October 18, 2016
32-30-6-877-590
Front passenger side airbag replaced at 110,669 miles on October 18, 2016
72-12-9-394-543
Passenger’s front airbag module replaced on May 15, 2021 at 119,142 miles
Part # 72-12-6-998-949
B650120 Recall: Takata Front Passenger Air Bag Module
INTERIOR
Upgraded the shaft boot to alcantara, along with weighted knob (oem available with same)
BMW armrest delete, OEM armrest is available with sale
No tears or wrinkles on the seats
Quarter panel had a dent (non accident related) Was professionally repaired and painted. Photos of before and after are available along with the body shop invoice.
All maintenance listed is accompanied with invoices.
The only cons I can seriously think of is the C pillars are sagging otherwise the car is ready to be enjoyed.
Clean title in hand. $28.5 obo
If the post is active the car is available
No trades. As
