E46 M3 Marketplace Owners Classifieds Electronics
      02-05-2021, 07:29 PM   #1
05SCM33
05SCM33's Avatar
30
Drives: 09 E92 M3
AutoEnginuity PC-Based Scan Tool with BMW Enhanced Expansion and Cables
USD 270.00
Shipping Costs Included
AutoEnginuity pc-based scan tool with cables and enhanced expansion for BMWs. I used it dozens of times while working on and diagnosing issues with both my E46 M3 and then my E92 M3. Don't have a BMW any longer but held on to this very useful tool in case I ever did get back into a BMW. Alas, time to let it go to another BMW enthusiast. I asking $270 shipped in the CONUS.
From AutoEnginuity's Website:
Enhanced Interface for BMW and MINI 1996-2020 (EI07)
Our enhanced BMW interface supports thousands of sensors and bi-directional controls selected from 200+ controllers such as engine (DME / DDE), transmission (EGS / SMG / DKG), ABS, airbags, and other body and chassis systems.
With our enhanced BMW, we support translating older BMW FC codes into OBD-II DTCs for all engine and transmission controllers. Also, supported is such trouble code status information as the fault frequency and fault conditions.
Model Coverage:
1 Series E8X/F21/F22/F87 (2004-2015)
2 Series F22/F23 (2014-2016)
3 Series E36/E46/E9X/F3X/G20 (1996-2016)
4 Series F3X (2015-2016)
5 Series E39/E6X/F1X/G3X (1997-2016)
6 Series E62/E63/F06/F1X (2004-2016)
7 Series E38/E65/E66/F0X/G11/G12 (1996-2016)
i3 I01 (2015-2016)
i8 I12 (2015-2016)
X1 X84/F48 (2009-2016)
X3 E83/F25 (2004-2016)
X5 E53/E7x/F15 (1999-2016)
X6 E71/F16 (2008-2016)
M3 E36/E46/E9X/F30/G20 (1996-2015)
M5 E39/E60/F11/G11 (1999-2015)
M6 E62/F16 (2004-2016)
MINI R50/R51/R53/R55/R56/R57/R60/F55/F56 (2001-2016)
Z3 (1996-2002) (1.9L, 2.0L, 2.2L, 2.3L, 2.5L, 2.8L, and 3.0L)
Z4 E85/E86/E89 (2003-2016)
Z8 (1999-2003)
System Tests:
Determine All Systems Present and Operating
Display Service and Inspection Information
Display Coding Information
Self-Test (Safety and Information)
Steering Angle Adjust (MK20, MK60, DSC 8, EBC 4, DSC 60PP, DSC Premium, EPS, SZL)
Lateral Acceleration and Pressure Adjust (MK20, MK60, DSC 60PP, DSC Premium [E46 non-M models, E8x, E9x, E6x, and MINI])
ABS Bleed (MK60 [on E46 '03+, E85/E86, and MINI models])
Service Functions:
Reset Airbag Light
Reset Conditional Based Service (E and F Chassis)
Reset Oil Service Light (for all 9/2000+ models)
Reset Service Interval Distance and Time (for all 9/2000+ models)
Register Replacement Battery BMW (E6x/E8x/E9x/Fxx/Gxx)
Register Replacement Battery MINI (R55/R56/R57/R60/F5x)
Reset DME, EGS, and RLS Adaptations
Reset EGS Oil Life Counter (6HP, 6HPTU, GM5, and GM6 units)
Reset VTG Oil Change
Set / Cancel Workshop Mode and Startup Electronic Parking Brake (EPB)
Clear and Set Transport and Sleep Modes
Window Initialization (E8x/E9x/E60/E61)
Driver and Passenger Seat Normalization (Fx0)
Normalize Driver Door for F07 / F10 / F11
Switch On Compressor Break-In Protection (E60/E61)
Teach In Clutch Slipping, Teach In Clutch Characteristic Curve, Teach Clutch Values, and Longitudinal Acceleration Sensor Offset (SMG II)
DDE 5.0 M47 / M57 diesel special function support:
Air Mass Flow Calibration
Reset Quantity Mean Value Adaptation
Reset EGR Calibration to Zero
Reset Injection Rate Reset Calibration To 100 Percent
Reset Consumption Calculation Reset To Calibration To Neutral
Request Particulate Filter Regeneration and Replace of Particulate Filter
DDE 6.0 N57 and DDE 7.0 N57 / N47 diesel special function support:
Reset Hot Air Film Mass Sensor
Reset Exhaust Back Pressure Sensor before Turbocharger
Reset EGR Valve
Reset Rail Pressure Regulating Valve Adaptation
Reset Radiator Shutter Variant
Reset Electric Fuel Pump Adaptations
Reset EGR Valve Adaptations
