Technical Sections Coding / Tuning / Audio-Video / Electronics
      04-04-2020, 09:28 PM   #1
x Spades x
210
Drives: BMW E46 M3
CSL SMG CODING inquiry
Hey Guys,
So i just got a dyno tune for my car, which included the CSL ECU and CSL SMG module tunes. The car drives great, but when i down shift (while braking), the car engine brakes immediately... no blip whatsoever. I almost get tossed into the windshield, that how hard the engine braking is. In S3, it seemscto blip correctly, but anything above that, its a violent jerk forward.
Has anyone else experienced this? Does the ECU have to adapt?
Thanks in advance!
      04-05-2020, 06:28 PM   #2
Andrew
Moderator
Andrew's Avatar
432
Drives: E46 M3 / E92 M3
2003 BMW M3  [0.00]
2008 BMW M3  [0.00]
CSL ECU? So I'm assuming you're running a CSL air box. Sounds like the transmission is downshifting without blipping the throttle. Right? So do you feel the same thing, but worse, when you down shift without braking?
I'm moving this to the Coding and Tuning section.
[Track] 03 AW/CIN 6MT E46 M3
[Street] 08 AW/FR 6MT E92 M3
[Tow/Overland] 23 Toyota Tundra HV TRD Off-Road
      04-05-2020, 08:08 PM   #3
x Spades x
210
Drives: BMW E46 M3
Thanks Andrew.
Yes, i have the CSL airbox with working flap. My ecu was converted to the csl version (h bridge). Yes, its the same feeling as downshifting without touching anything. So is no blip, just kill myself engine strain
      04-05-2020, 08:40 PM   #4
Andrew
Moderator
Andrew's Avatar
432
2003 BMW M3  [0.00]
2008 BMW M3  [0.00]
Originally Posted by x Spades x View Post
Thanks Andrew.
I would check the CSL SMG parameters. Definitely should rev-match downshift. You can also try ECUWorx's MSS54/HP tool to enable CSL interetia update and make sure rev matching is enabled.
      04-05-2020, 09:54 PM   #5
x Spades x
210
Drives: BMW E46 M3
I have Martyn's tool. When i upload my bin, CSL intertia and downshift blips are greyed out... :-(.
