08-23-2014, 10:27 AM | #551 |
11817
Rep 23,187
one of my videos from thursday. didnt catch my opening session which has the fastest laps due to fresh c51s. this is second session and lap 2 is a mid 1:53 and lap 3 is md 1:52 with a pass on mustang that slowed me down a bit. end of the video has me playing around with a gt3rs on hoosiers. most fun of the day was running nose to tail freight train on rest of field with santo in e92 and george in the gt3rs. we switched positions a few times and ended up getting the pass on gt3rs as he spun off at 11.
08-30-2014, 10:53 AM | #552 |
11817
Rep 23,187
another video from this weeks sessions. only of interest because it shows me getting by the new vette in the first part of the session. he put a big gap on me down the front straight but not enough to hold me off by turn 8 after i closed considerably in the carousel.
Later in the day i heard an instructor telling someone their demo z51 was way faster than my car so i proceeded to follow him out and passed him without any struggle?
08-30-2014, 07:45 PM | #553 |
1577
Rep 8,077
Drives: 11 E90 M3 Individual
Lol...nice!
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
09-01-2014, 06:10 PM | #554 |
11817
Rep 23,187
12k posts.
09-01-2014, 06:20 PM | #555 | |
915
Rep 3,456
Drives: Harrop E90 M3
09-01-2014, 06:22 PM | #556 |
11817
Rep 23,187
yep still waiting on my check from the forum for being a shill.
09-01-2014, 07:15 PM | #557 |
1577
Rep 8,077
09-11-2014, 09:53 PM | #559 |
11817
Rep 23,187
thank you sir still has a long way to go until im satisfied with it.
09-11-2014, 10:17 PM | #561 |
11817
Rep 23,187
i have mcs singles with 700/800 rate springs.
09-11-2014, 10:20 PM | #562 |
11817
Rep 23,187
got in a set of bfg r1 in 265 since run so wide, a set of maxis rc1 also to give a try as a replacement for nt01s, and a set of conti scrubs from another member. goal is to try out most of the radial rcomps and see which i like best in terms of lap times and which is the bargain to be used more regularly that last longer and dont fall off too bad.
09-11-2014, 10:48 PM | #563 |
11817
Rep 23,187
shot of my car from this last weekends griots garage car show. got a feature spot up on the sidewalk thanks to fellow member on the forum who was the chair for the event.
09-12-2014, 03:59 PM | #564 |
4986
Rep 11,891
I can barely see through the windows in that pic, but it appears you've install the factory code: ZXXX option? e.g. stripper pole?
09-12-2014, 04:43 PM | #565 |
11817
Rep 23,187
09-13-2014, 11:05 AM | #566 |
Rep 16
im on MCS DBL internal (no canister) too many adjustments for novice guys like me =) - using 550/650 hyperco springs. My car nonstreet legal/stripper so a bit lighter.
I dont have much experience/slow learner so i tried softer springs (450/550) to slow things down - after about 6 events, im changing back to 550/650. Too soft. I alsl disconnected rear sway bar and have GC front on full soft... testing continues. Loving your car btw.. we have same color =) Tiag is a fast color Last edited by dc640; 09-13-2014 at 12:03 PM.. |
09-13-2014, 02:19 PM | #567 | |
11817
Rep 23,187
09-13-2014, 02:21 PM | #568 |
11817
Rep 23,187
update. ordered an electric garage heater for working on the car this winter and to maintain temp high enough for rcomps in there. excited to have it. just gotta hard wire the thing with 240v and 30 amp breaker.
09-14-2014, 12:20 AM | #569 | |
Rep 16
my car weights 2632lb w 7/8th fuel full.. needle about 3 mm left of full mark.. is that 7/8th or about 15 gallons of fuel? One of the challenges I had was the car not having enough mechanical grip and rear being loose with rear csl sway so im disconnecting them. Im using 275 square nt01 w 3.6/2.3 camber and 1mm toe out (f) and 1.5 toe in (r). ive been trying to run 32/34 hot regarding tire pressure. |
09-14-2014, 12:41 AM | #570 | |
11817
Rep 23,187
09-14-2014, 01:12 PM | #571 | |
Rep 16
I talked to Lex at MCS - he says "usually as far as rebound rules, with front engine rear wheel drive cars (like ours) the rear rebound is usually lower than front rebound. I may be taking his quote our of context but it kinda made sense when we were discussing "loose rear end" what tires do you have in mind? |
09-14-2014, 11:03 PM | #572 |
11817
Rep 23,187
as mentioned above i am trying various rcomps out over this next year. just had a set of hankook c51. next i have bfg r1, maxis rc1 and continental scrubs. thought i would also try hoosier r6, kumho v710 and maybe toyo rr.
