03-28-2024, 07:23 PM | #45 | |
Rep 1,191
You can turn down the CP amperage within the CP app; that is where I would start. Good luck! |
03-28-2024, 07:32 PM | #46 | |
Rep 933
Drives: ix xDrive50
2024 iX xDrive50 Phytonic Blue on Mocha with DAPP, Premium, B&W, Ventilated & Radiant Heated Seats, Adaptive Headlights, and Luxury
03-28-2024, 08:18 PM | #47 | |
Rep 133
03-29-2024, 09:55 AM | #48 | |
Rep 1,191
03-29-2024, 10:07 AM | #49 |
Rep 933
Drives: ix xDrive50
Thanks. There was so much shared, and it is such a perplexing problem, I wanted to get all the nuggets in one place.
thebishman607.00 |
03-29-2024, 11:59 AM | #50 |
5589
Rep 4,525
Drives: 2022 iX xDrive50, DGM
Good synopsis. As an observation, a breaker doesn't need to trip to cause a charging fault, overheat or intermittently fail. A breaker will eventually wear out (or can be faulty to begin with), connections can be loose, or any number of other source problems. Replacing it (with a known, good breaker) would rule out one possibility.
03-29-2024, 03:30 PM | #51 |
Rep 133
Perplexing indeed. I’m wondering IF there is an issue with wiring, maybe the car knows something is off and stops but the Jeep Willy isn’t as “smart”?
03-29-2024, 03:31 PM | #52 | |
Rep 133
03-29-2024, 04:19 PM | #53 | |
Rep 933
Drives: ix xDrive50
I would do what Paladin1 suggested above: replace the circuit breaker. The reasoning is that maybe you have a bad connection or issue in the breaker causing a voltage drop. Replacing it and securing the wiring again could correct it (and eliminate another possible cause). I would also put a voltmeter on the ChargePoint and service panel to see exactly what the voltage drop is.
Paladin15589.00 |
03-29-2024, 10:59 PM | #54 | |
Rep 133
03-29-2024, 11:10 PM | #55 | |
Rep 133
Stay tuned… |
03-30-2024, 10:10 AM | #57 |
5589
Rep 4,525
Except - didn't it work with other cars?
03-30-2024, 01:36 PM | #59 |
5589
Rep 4,525
It's a puzzler, but you seem to have isolated it - somewhat - to the car itself, at least the car paired with your home setup. The CP EVSE works with other cars, circuit works (absent some finding by an electrician, if you choose), other EVSEs work with your car outside your house. Car doesn't work in your house with your existing setup. This points to some unknown interaction with your car, your home EVSE and/or your home circuit. One variable you haven't tried is a different EVSE. That would narrow it down pending results to either some interaction with the CP EVSE by itself and your car (if the swap is successful), or your home circuit + CP and your car (if not). Got to be a frustrating hunt.
03-30-2024, 03:47 PM | #60 | |
Rep 133
Bad second/replacement charger? |
03-30-2024, 03:53 PM | #61 |
5589
Rep 4,525
Could happen, however unlikely it might be. “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” (A.C. Doyle)
03-30-2024, 04:08 PM | #62 | |
Rep 133
So I compared my friend’s unit to mine - they sent me the Nema 50 version wonder if that makes a difference if hardwired to 60a? The other difference is firmware 5.5.4.4 on theirs vs 5.5.4.8 |
03-30-2024, 04:25 PM | #63 |
5589
Rep 4,525
The difference in versions is that you won't get a cord and plug with the hardwired version, and the hardwired version works with breakers rated to 80 amps - the HomeFlex can be set to deliver up to 50A in the hardwired configuration. In your case with your description, I assume you have a 60A breaker delivering 48A to the car (hardwired) - outlet circuits generally have a 50A breaker. Most code also now requires a GFCI breaker inline. That's why I suggested that a qualified electrician familiar with EV installation check your setup, to make sure everything is torqued to spec and wired to spec. Your CP unit charges other cars, so something in your car seems to be causing the glitch. That may or may not be related to the way your CP unit is set up, or as you speculate something in the software settings of car or CP app.
03-30-2024, 04:44 PM | #64 | |
Rep 133
03-30-2024, 06:56 PM | #65 |
Rep 133
can whoever has a chargepoint flex, please post the firmware version? another avenue I'm looking down is the firmware version between when it worked and when it stopped. the new unit is on 5.5.4.8, the old unit I can't recall but friend who has 5.5.4.4 has it working for me. I don't know when 5.5.4.4 came out, according to the support line the new version was about 3 weeks ago which brings it to the March 8 timeline. I can't recall if I had tried charging on March 4th or not but the next time an attempt was made was March 8 or 9. March 10 is when I made the first call to support after having realized the issue.
03-30-2024, 07:11 PM | #66 |
Rep 933
Drives: ix xDrive50
