04-18-2024, 03:10 PM | #1 |
Rep 658
Anyone phone gets hot from charging in the car?
Been charging my cell phone using a usbc wire in the car on distance drives and notice after a half hour the phone feels really hot. Never had that issue when charging in my X6M
04-18-2024, 03:17 PM | #3 | |
Rep 934
Drives: ix xDrive50
I got one of these and absolutely love it! BMW iX MagSafe-Compatible Wireless Charging Stand
2024 iX xDrive50 Phytonic Blue on Mocha with DAPP, Premium, B&W, Ventilated & Radiant Heated Seats, Adaptive Headlights, and Luxury
04-18-2024, 03:28 PM | #4 |
Rep 740
Drives: '24 iX M60 '23 Tesla Model Y-P
I did notice yesterday that if the phone is too hot the car's wireless charger will not charge it, but it does sense it and will remind you to to remove it when you turn the car off (if you have that setting turned on).
04-18-2024, 03:28 PM | #5 | |
Rep 96
deutsch1004014.50 |
04-18-2024, 04:11 PM | #6 |
5597
Rep 4,527
Drives: 2022 iX xDrive50, DGM
My Android phone (S24 Ultra) gets no warmer than on my home charger which is just warm to the touch. Otterbox Defender case; charges fine.
unfoundnemo1920.00 |
04-18-2024, 06:36 PM | #8 |
5597
Rep 4,527
Overheating is more commonly reported using the QI pad, as above. No type or model of phone specified, or which port, but if it overheats with a USB cable, perhaps the solution is to use the pad. Or use a different cable. Or check the cable elsewhere to see if the phone otherwise overheats. There shouldn't technically be any difference charging with a cable wherever you charge, because the phone itself (most of them) should limit the input to the battery through the USB, but IIR someone has checked the amperage through the USB-C ports in the iX somewhere in the forum.
04-18-2024, 06:46 PM | #9 |
Generalissimo
660
Rep 1,419
Slightly off topic but I noticed that iX’s wireless charging pad has cooling vents and I hear some fan noises when my iPhone is charging wirelessly. Do the phones still get hot when charging using the iX’s build-in wireless charger? I turned mine off because I don’t want to constantly charge my phone wirelessly. My phone was getting very hot in my previously owned X5 45e. But the wireless charger there had no cooling vents and no ability to be turned off.
04-18-2024, 07:26 PM | #10 | |
Rep 263
Every car that I have driven that has a Qi charger has heat issues even if out in the cars qi pad |
04-18-2024, 07:41 PM | #11 | |
2484
Rep 1,975
I think some models (like iPhones) have more issues than others. Some phone cases cause more issues as well; i use a bumper guard style case with my phone which doesn't cover the back of the phone which can interfere with the phone's ability to cool down. |
04-18-2024, 07:45 PM | #12 | |
Rep 263
04-19-2024, 11:38 AM | #13 | |
Rep 24
04-19-2024, 11:49 AM | #14 | |
Rep 934
Drives: ix xDrive50
That ring is super clever. I did not see that, but I did not need it since I have an Apple iPhone. However, that little ring makes the MagSafe stand work for any type of non-Apple Qi phone.
04-19-2024, 12:50 PM | #15 |
Rep 48
Drives: Tesla Model S, Tesla Model 3,
Here a pic of the same one which I got which is tilted to the driver. Wishe I had a black Apple charger.
04-19-2024, 03:32 PM | #16 |
3114
Rep 3,074
Drives: 2023 iX M60 Oxide
This is all subjective though. I haven’t had a phone *not* feel warm, sometimes uncomfortably so, when fast charging in the sweet spot (say anything under 60%), regardless of charging method.
What I will say is that with car wireless chargers, often the phone feels hot but also hasn’t charged much (X3, e-tron, XC90, iX). Whereas if I plug-in to USB C PD, the phone will get hot but also go from 20% to 60% in under ten minutes. Also often these charging pads are exposed to the sun and the phone gets hot that way too. This is actually the only case I’ve encountered where the phone itself complains about being too hot or starts noticeably throttling. |
04-20-2024, 03:40 PM | #17 | |
Rep 24
I've seen pictures with black MagSafes but I think they are putting something black over the white Apple MagSafe charger |
04-20-2024, 04:13 PM | #18 |
Rep 48
Try this: driver facing
04-20-2024, 10:54 PM | #19 |
Rep 48
04-23-2024, 12:15 PM | #22 |
1920
Rep 2,011
Drives: 2022 i4 M50
Running carplay itself isn't horrible, but CarPlay + Maps + Audio will typically do it (which is probably why you're running CP to begin with). Not as bad in the iX as some others as there's more ventilation, but reducing the distance between the coil on the charger and that on the phone is what is key... more distance = more heat, which is why something like a magsafe charger is better (thinner plastic and more accurate position).
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
