      08-17-2021, 10:03 AM   #1
mikehest22
Drives: BMW E46 M3
Cleared codes with OBD scanner, now car won't start. HELP!!!
I Borrowed a friend's Foxwell NT530 OBD scanner and ran a scan for codes. Car was running fine before, always started right up. I had a CEL and just wanted to check and clear codes to see what popped back up. I cleared each code and now car turns over once and then dies. The battery is fine, not sure what I may have done wrong. What is my best course of action?
      08-17-2021, 10:23 AM   #2
mikehest22
Drives: BMW E46 M3
It is a 2001 E46 M3
      09-09-2021, 10:23 AM   #3
Obioban
Emperor
Obioban's Avatar
1614
Drives: M3, M3, M5, M5
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2005 BMW M3 Coupe  [0.00]
2001 BMW M5  [0.00]
Turning over once and then dying is generally an EWS issue. Easy check would be to disable EWS using MSS5X binary modification tool. If that was the issue... may or may not be worth fixing. It does make the car marginally harder to steal.
https://nam3forum.com/forums/forum/s...on-tool-update
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport
