E46 M3 Coupe and Convertible Forum Photos, Videos, Builds
      01-30-2014, 02:21 PM   #45
Obioban
Emperor
Obioban's Avatar
1614
Drives: M3, M3, M5, M5
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2005 BMW M3 Coupe  [0.00]
2001 BMW M5  [0.00]
Yesterday I converted my fan setup from the stock aux/clutched fan to a Z4M inspired SPAL electronic puller fan setup (16" medium depth). Because fan capability is reduced, I retained the stock fan shroud to make the most of my SPAL fan. Side note, fans are only really used when sitting in traffic or for the AC compressor, so cooling capacity at speed should not be changed by the project.
I'm using the factory aux fan controller to control the SPAL speed. Because it's now the only fan (instead of an aux fan), I'm changing the ecu fan control values to that of the Z4M (which also only has an electronic puller fan).
Project goals, from most important to least:
longer water pump service life (as no fan/clutch wearing the bearing)
no more fan/fan clutch replacements
decreased weight
remaining weight moved inboard
decreased parasitic loss on the engine
Some pics...
Front bumper and ducting removed so I could pull the factory aux fan:
Factory aux fan controller, which I added a plug to to connect to the SPAL fan:
SPAL fan mounted on the factory shroud. I wanted it easy to remove and to not damage the radiator. This way it removed with the shroud, and just adds one plug. I reused the hardware from my trunk decontenting project (added loctite and the silver bits aren't visible once installed:
And installed. These two black bolts are all you can see once it's in, and they get further hidden by the air duct that goes on top:
From the other side:
Saw my dealer taking this down and snagged it.
A friend of mine just made this video from my bachelor party. Pretty awesome, IMO!
CNF GoKart 082413 - YouTube
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport
      01-31-2014, 12:43 PM   #46
DB
M3/Raptor
DB's Avatar
Drives: to the track
Even though I knew about much of the stuff you have done to the car (there was also much I didn't really know), reading through this makes it even more impressive. And some of the photos are just awesome.
      02-05-2014, 08:31 PM   #47
Obioban
Emperor
Obioban's Avatar
1614
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2001 BMW M5  [0.00]
Took some pics of the beater this afternoon
Icy trees kind of make a cool backdrop, so...
      02-14-2014, 12:45 AM   #48
MugenM3
Drives: E46 M3, Jet Black/Black
Great project and work Obioban!!!!!!!!
      02-22-2014, 04:28 AM   #49
Obioban
Emperor
Obioban's Avatar
1614
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2001 BMW M5  [0.00]
Goodbye hyper black RAC RG63's
Hello anthracite RAC RG63's
(Traded last night)
      02-23-2014, 07:09 PM   #50
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
More info on the SPAL fan...how did you wire it in?
For the lightweight stereo...I've got a car audio setup with 5 speakers. Maybe stick with a set of front comps with a neo magnet on the mid (Alpine, MBQ and JL make some) and 5 channel class D amp. Then get a decent single din and remove the OEM wiring harness. That will save you another 10-15 lbs total easily. The OEM stereo harness is pretty damned heavy for just wires.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      02-24-2014, 06:49 AM   #51
Obioban
Emperor
Obioban's Avatar
1614
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2001 BMW M5  [0.00]
I would, but I hate aftermarket head units and love the OE nav. Plus, I have everything going through it-- on board diagnostic displays, nav, iPhone, iPod, triple bling turn signals, vehicle journaling/logging, light control, etc. Plus, every aftermarket single din head unit looks like ass in the e46. Nav is the only option on the car that I consider mandatory. Never seen an amp lighter than the one I'm running.
I wired the spal to the factory aux fan controller (deleted the aux and clutched fan when I installed the SPAL), and had Evolve change the aux fan controller to the Z4M fan controller temp values (the Z4M has an S54 but only has an electronic puller fan, which is my current setup with the SPAL).
      02-27-2014, 09:28 AM   #52
Obioban
Emperor
Obioban's Avatar
1614
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2001 BMW M5  [0.00]
Two small updates:
A) I have a bimmerworld/C&R oil cooler on its way to me. Exciting!
B) I'm working on devising a steering feel upgrade for the M3. My plan of attack is two fold...
1) replace the steering guibo with the joint from the e28 M5
2) replaced the 60mm centered FCABs from the e46 with 66mm eccentric FCABs from the Z4M (much like 96-99 e36 M3 will often retrofit the eccentric FCABs form the 95 M3.
Guibo portion should be easy, goes from (part 2)
to (part 11)
or, from
to
For context, the Z4M shaft, bushing free (this is what really sold me on doing this and not regretting it)...
FCABs are a little more interesting. The e46 M3 housing is 60mm, so the bushing isn't plug and play. The e46 non M has a 66mm bearing hole, but it doesn't have the third hold for our thrust plate (which I don't want to give up). It appears (I need to verify) that the outer diameter of the e46 non M FCAB lollipop is the same diameter as ours. If that's the case, I'm going to throw a set of e46 M3 FCAB lollipops on the lathe and mill 3mm of radius. Presto, 66mm e46 M3 fitment FCAB lollipops
Z4M stock lollipop with eccentric bushing:
e46 M3 lollipop with centerer bushing:
e46 non M FCAB bracket (thinner walls, so... hopefully okay for us to be that thickness):
      03-10-2014, 09:29 AM   #53
s85e90
192
Drives: black e90
Originally Posted by Obioban View Post
Two small updates:
to (part 11)
or, from
to
I have a set of stock old FCAB if you need; PM me
      03-10-2014, 03:17 PM   #54
Beedub
United Kingdom
423
Drives: 2007 Z4 M roadster vt2-500
incredible thread tbh..... really enjoyed slowly reading this tonight.
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com
      03-12-2014, 08:31 PM   #55
sharocks
Drives: Normal Kidney Grill'd BMWs
Thanks for the DIY Clutch Stop! My foot hurts less in traffic now!
      03-12-2014, 10:15 PM   #56
lsmkr01
lsmkr01's Avatar
Drives: E92 M3
100% You take DIY to whole new dimension.
      03-13-2014, 05:23 AM   #57
Obioban
Emperor
Obioban's Avatar
1614
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2001 BMW M5  [0.00]
Thanks guys.
Should have an exciting update, soon.
      03-13-2014, 07:00 PM   #58
auggiem3
auggiem3's Avatar
Drives: F87 M2C & E92 M3
Wow - amazing story! Saw your wedding pic in roundel.
      03-28-2014, 05:45 AM   #59
Obioban
Emperor
Obioban's Avatar
1614
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2001 BMW M5  [0.00]
Not directly related, but since this is an e9X forum, probably makes sense to post anyway...
Picked this up yesterday morning, going to be the wife's new DD.
Rear wheel drive
NA
Manual
Hydraulic power steering
No DI
no iDrive
The last of the purchasable BMW's, imo, as all of the above were minimum requirements for me.
Currently it is a 328i, but soon it'll be a Supersprint header/evolve tune 330i, which will put it at (a reliable, NA) ~300 crank HP.
After this summer these wheels will become winter wheels, and we'll get something light/strong for the summer with real tires.
Needs M3/1M subframe bushing asap, and have to figure out what I'm going with suspension on it. Likely it'll be stock sport springs with Koni yellows or Bilsteins.
Roof rack will also be removed.
But, first order of business will be swapping all the fluids!
May dye the vinyl parts of the interior black for a two tone effect, undecided on that...
50,000 miles on the clock, currently. This should be a fun and reliable car for a long time, given how it's optioned.
I really love the non iDrive radio/sirius/bluetooth/ipod interface. Looks old school, but with new school functionality.
      03-28-2014, 03:33 PM   #60
mbox
mbox's Avatar
Drives: ///M
love the wagon....keep us posted!
      03-29-2014, 02:23 PM   #61
Obioban
Emperor
Obioban's Avatar
1614
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2001 BMW M5  [0.00]
Ordered konis, eibachs, m3 subframe bushings, roof rack delete kit, oem iPod interface, and every fluid in the car. It begins!
      03-29-2014, 03:24 PM   #62
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
One of the best E46 M3s out there.
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      03-30-2014, 04:27 AM   #63
comar1979
130i Treiber
comar1979's Avatar
Germany
119
Drives: BMW 130i
I your M3!!! Very very nice
Red BMW´s are a blast
# BMW 130i /// + SPARCO Assetto Gara 8x18 bronze + KW + PP SteeringWheel II +PP Exhaust +PP Kidneys + PP AirFilter + PP Style Flaps + PP SS Kit + AC-Schnitzer Gear Knob + MorVision Diffusor + LCI Blacklines high + GroundZero-Audio #
      04-05-2014, 08:08 AM   #64
Obioban
Emperor
Obioban's Avatar
1614
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2001 BMW M5  [0.00]
Happy new wheel day! Every car got wheels they've never run before.
e46 got a set of anthracite RG-63's that I traded my hyperblack RG-63's for over the winter. Much better match for IR, imo!
e91 got a set of 17" BBS SR's. They look AWESOME now (way better than in this pic), but are going to look even better next week when we take it off the non sport suspension:
e39 got a set of 18" BBS RG-Rs in silver. Never seen silver RG-Rs before, the color goes quite nicely with Le Mans blue, I think!
... all cars need washes. It's been winter, what can I say :clueless:
Could have also used a non phone camera and non rainy day, but.. reh. arrot:
      05-21-2014, 10:24 AM   #65
Obioban
Emperor
Obioban's Avatar
1614
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2001 BMW M5  [0.00]
Over the winter I traded RG63's with another member for anthracite. I'm so very pleased with how it goes with the IR-- very much more what I imagined when I ordered the hyper black than I ended up getting!
      05-21-2014, 01:04 PM   #66
thetastelingers
Master Baiter
thetastelingers's Avatar
4171
Drives: 18 M2
2018 BMW M3 SOLD  [10.00]
2018 BMW M2  [9.67]
Wow I haven't been on here in years. Glad to see you are still modding and posting. I'll be up in PA next Friday to pick up my new to me M3.
Back in a BMW again.
Anyway keep up the good work man!
The wheels look good on all of them!
