      03-10-2012, 01:34 PM   #1
dumpedDaily
Drives: CB 2002 E46 M3 SMG
2002 E46 M3 Not Starting!
Hey all. I've got a little problem here. My car decided to just want to crap out on me last week. Here are some details.
Car: 2002 M3 SMG
Mileage: 117000
Problem: No start
Symptoms:
- Car would need to be jumped to start at times
- Car would sometimes start on its own without a jump
- Service and smg light would turn off and on
- Would shift out of gear while driving on HWY
- SMG/Fuel pump currently not priming but was going in and out
- Had a leak in the driver front tire which caused car not to start
- Will not go into let me select any gears when car is on or off
- Makes a spark sounding noise after turning key back to the off (0) position
Actions Taken:
- Checked stock battery life (60%) charged it to 100% but depleted to 80 once off the charger. Put the stock battery back and still didnt start.
- Checked a majority of the fuses in the glove box
- Replaced batterty with Braille 15 lb battery
- Replaced Salmon relay under hood fuse box
- Tried different keys
- Open and closed hood, trunk, gas cap, and both doors. Sometimes worked!
- Replaced rims and tires from 19" ZCP to base 18"
I hope to find what the issue is myself before going to the stealership for repair. Any suggestions as to what will help fix the problem would be really appreciated. Ive read numerous threads on this type of problem and have seen it to be the battery or salmon relay. Ive also seen that it could be faulty ignition swith or brake switch. Some say starter but it clicks when I try to start the car. Either way I NEED HELP!!!
Thanks in advance.
      03-10-2012, 03:30 PM   #2
dumpedDaily
help please!
      03-11-2012, 10:30 AM   #3
dumpedDaily
Wow you guys are awsome! Not one person to help out. Can somone shed light on my situation. It's not like I only posted "my car doesn't work, whats wrong?" I put details to help narrow the problem down. I know someone has had to deal with this...
      03-11-2012, 06:06 PM   #4
flipm3
E46 + E90 + F80
192
Drives: E46 + E90 + F80
2009 BMW M3  [0.00]
2002 BMW M3  [0.00]
I haven't personally dealt with such situation before, so I am definitely not going to be the biggest help.
You may want to check out www.m3forum.net if you haven't already. There are much more knowledgable and experienced people there regarding the E46 M3 than here. M3Post is primarily for the E90 crowd.
Best of luck! I wish I could suggest something, but I'm really not sure.
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread
E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread
      03-11-2012, 06:11 PM   #5
dumpedDaily
Thanks bro. Im on there too and they are trying to help me out. I just figured I'd try on as many forums as possible to get some kind of fix.
      03-11-2012, 06:15 PM   #6
flipm3
E46 + E90 + F80
192
2009 BMW M3  [0.00]
2002 BMW M3  [0.00]
Cool! Well best of luck. Definitely update this thread when you get the chance for historical sake
      03-11-2012, 06:30 PM   #7
dumpedDaily
Definetly will. Im sure many others will have this issue since it seems to be a common issue.
      03-16-2012, 12:38 PM   #8
hankcah
Drives: BMW 335i E90
2007 335i  [0.00]
What's the scoop with your car. I noticed its been at least a couple of days since the beginning of your troubles?
Any resolution?
