      04-10-2023, 05:38 PM   #1
702RIP
13
Drives: 01 E46M3 LSB
01 Rod bearing upgrade
What is the best rod bearings upgrade available…
Currently 87k miles and no issues but wanted to do preventive maintenance for weekend car and street + type driving
Thanks
      01-14-2024, 10:10 PM   #2
MAMSport
MAMSport's Avatar
94
Drives: '13 128i M-Sport coupe
I am one of thousands of drivers who had to replace the rod bearings. On my '02 M3, it had bearings changed as part of the service action (NOT technically a recall). I was aware of the potential for further wear, so I monitored the condition by having regular oil analysis (every other change). This pointed to increase in lead and some copper in the oil about 100k miles after the service action, so the decision was made to replace the replaced bearings. My indy tech, a former BMW master tech who specialized in E46 M3s and who had previously owned an E30 M3, and I discussed the different alternatives. We concluded that OE bearings made the most sense, and if we got to another 100k miles and needed to change again, it would be acceptable. I ended up selling shortly after the bearings and oil pump replacement though (total miles about 135k and 100k after original replacement).
E9x M3 front & rear suspension arms; BMW Performance brakes upgraded to drilled rotors in rear; BMW performance shifter; BMW Performance Exhaust; Wave Trac LSD with modified 'nannies'; BMW Euro Intake box; BMW Aluminum Strut Tower bar; ECS front and rear sway bars; 3 stage intake with BPC software; BMW style 78, 17 x 8" wheels with Bridgestone RE 980AS 225/45-17 tires; Koni Special Active struts/shocks, E9x M3 RTABs.
      01-24-2024, 04:19 PM   #3
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9599
Drives: G82 M4 / G87 M2
Thanks
We don't have any skin in the game as these aren't parts we generally sell, but we prefer WPC treated OE bearings or straight OE bearings on our own cars. We generally don't recommend coated bearings.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
