      08-22-2020, 06:35 AM   #1
mcmahonbj
Drives: 2004 BMW M3
FS: 2004 BMW M3 Coupe 6-Speed AW
SOLD
  • 2004 BMW M3
  • --VIN #: WBSBL93424PN56528
  • --145,977 Miles (About 3k During My Ownership)
  • --Power Front Windows, Power Locks, Exterior Lights Work
  • --Over 30K In Receipts (Two Binders Full)
  • --One Normal Key, One Valet Key, And Owners Manual
  • --Subframe Reinforcement Done
  • --Vanos Bulletproofed Done
  • --Rod Bearings Not Done To My Knowledge
  • --Willing To ship (Located Madison, WI 53704)
Exterior
  • Automotive Lighting (AL) Clear Turn Signals
  • BimmerWorld Matte Black Front Grills
  • Hard Motorsport Polycarbonate Rear Side Windows W/ Mounting Hardware
  • LED Automotive LED License Plate Lights
  • Motion Motorsport Underpanel Kit
  • Non-OEM Replacement Fender Grill Badges
  • OE Clear Fender Side Markers
  • OE European Front Bumper
  • OE Chrome Fender Grills
  • Osram DS2 Bulbs
  • Rolled Front Fenders
  • Zealous Manufacturing License Plate Hardware
  • Zealous Manufacturing Rear Quarter Window Hardware
Interior
  • AKG Delrin Clutch Pedal Bushing
  • Artisan Research CF Driver Floor Plate
  • Brey Kraus Clip-In Lap Belt Mounts (Driver/Passenger)
  • Brey Kraus Manual Slider Release Mechanism (Driver/Passenger)
  • Brey Kraus OEM Manual Slider Seat Brackets (#R-9220 & #R-9221)
  • Brey Kraus Sub Strap Mount (Driver/Passenger)
  • Custom Aluminum Glovebox Delete Panel
  • Custom CAE Hump Block-Off Panel
  • DEKA ETX 14L Battery (12 lbs.)
  • EuroCustomsPR Red Cluster Overlays
  • Halguard H3R Clean Agent 2.5lb. Fire Extinguisher (Black)
  • Hard Motorsport 2pc Dash Vent Block-Offs (Outer Only)
  • Hard Motorsport Lightweight Door Panel Set
  • Hard Motorsport RS Door Pull Conversion Kit (Red)
  • Motamec UK Co-Drivers Footrest
  • Niko CarbonWorks CF Horn Delete Plate
  • NRG Short Hub Adapter
  • OE Armrest Delete Kit W/ New Inserts
  • OE E46 European Rearview Mirror
  • OE Glasses Storage Tray
  • OE Non-HK Inner Door Handles
  • OE Saloon/Compact (Front Windows Only) Shifter Surround Trim
  • OE Saloon/Compact Window Switches (P/N:6902177 / 6902176)
  • OE Titan Shadow Interior Trim Set
  • Pegasus Racing Air Duct Hose For Air Ducts W/ Rubber/Steel Loop Support Clamps
  • Pegasus Racing NACA Medium Clear Air Ducts
  • Phase2 Aluminum Hose Clamps (Hose to Duct Attachment)
  • ProTech Composites CF Plate For E-Brake Handle Delete
  • Rennline 4pc Aluminum/Rubber Pedal Set (P/N: P71.60.56)
  • Rennline Battery Relocation Mount Kit (Switch Mount)(#EL41.34)
  • Rennline Pedal Lifter Plate (P/N: PA71)
  • Rennline Throttle Extension (Red) (P/N: PE70_71HT)
  • RHR Performance CF Center Dash Panel
  • Rothsport Steering Wheel Quick Disconnect (Red)
  • S2R Tuning Fiberglass Sunroof Delete Panel
  • Sparco Evo II Seats (#008282FNR) (Pair) (Expiration 2023)
  • Sparco R 383 Steering Wheel
  • Street Faction Engineering Aluminum Rear Seat Delete Kit (3pc. Kit W/O Speaker Cut-Out)
  • TRS UK Steering Wheel Protective Cover
  • Vibrant Performance Split Harness Wrap Throughout Interior
  • Zealous Manufacturing Air Duct Hose Clamp Hardware
  • Zealous Manufacturing Custom CF CAE Shifter Surround Panel
  • Zealous Manufacturing CF Driver Floor Plate Hardware
  • Zealous Manufacturing Door Panel Hardware
  • Zealous Manufacturing E-Brake Delete Panel Hardware
  • Zealous Manufacturing Rear Seat Delete Panel Hardware
  • Zealous Manufacturing Seat Bracket Hardware
  • Zealous Manufacturing Sunroof Delete Panel Hardware
  • Zealous Manufacturing Trunk Hinge Hardware
  • Zealous Manufacturing Trunk Lock Hardware
  • Ziza Master Interior LED Kit (Driver/Passenger Front Footwells Only Now)
Suspension
  • AKG 65D FCAB
  • AKG Rear Shock Tie Downs
  • BC Racing BR Type Coilovers Front: 8k / Rear 12k
  • ECS Tuning Front Strut Reinforcement Plates
  • Ground Control Front Sway Bar W/ Endlinks (Large)
  • Ground Control Rear Sway Bar W/ Endlinks (Large)
  • Mason Engineering Front Race Strut Brace (Aluminum)
  • Turner MS Rear Control Arms
Drivetrain
  • CAE Shifter (Silver Aluminum/Black Delrin Knob)
  • Radenergie Stainless Steel Shift Link
  • AKG 75D Transmission Mounts
Engine Bay
  • OE Coolant Reservoir Relocated
  • OE M3 Vented Engine Beauty Cover W/ New OE Emblem
  • Vibrant Performance Split Harness Wrap Throughout Bay
  • Zealous Manufacturing aFe Intake Hardware
  • Zealous Manufacturing Catch Can Mount Hardware
  • Zealous Manufacturing Co-Driver Footrest Hardware
  • Zealous Manufacturing Coolant Reservoir Mount Hardware
  • Zealous Manufacturing Core Support Hardware
  • Zealous Manufacturing Fender Bolt Hardware
  • Zealous Manufacturing Firewall Block-Off Panel Hardware
  • Zealous Manufacturing Hood Hinge Hardware
  • Zealous Manufacturing Hood Lock Hardware (Core Support Side)
  • Zealous Manufacturing Hood Lock Hardware (Hood Side)
  • Zealous Manufacturing Power Steering Cooler Bracket Hardware
Engine/Performance
  • AFD ProFlex Commander E85 Kit (Flex Fuel)
  • aFe Power Stage-2 Pro Dry S Intake System
  • AKG 75D Motor Mounts
  • Auxillary Fan Delete
  • AVT-Innovations Intake Scoop (Black)
  • BimmerWorld Brass Coolant Bleeder Screw
  • BimmerWorld Radiator Coolant Hoses
  • BimmerWorld Diffuser Exit Straight Pipe Race Exhaust
  • BimmerWorld Heater Core Delete Kit
  • BimmerWorld Vanos SS Line
  • BuildJournal Loaded Tune
  • Clutch Fan Delete
  • CPV Upgraded O-Ring
  • Earls Hose Separator Clamps (Catch Can Hoses)
  • Earls Hose Separator Clamps (Oil Cooler Lines)
  • Earls Hose Separator Clamps (Power Steering Lines)
  • Hack Engineering Power Steering Cooler Kit W/ MOCAL Cooler And Aeroquip AN Fittings
  • Hard Motorsport Firewall Block-Off Panel Wrapped In DEI Gold Heat Tape
  • HPS Coolant Relocation Hoses W/ HPS Embossed Clamps
  • HVAC Delete (Heat and A/C)
  • JVT Headers
  • Mishimoto Radiator
  • Mishimoto Oil Cooler Kit
  • N15 Fan Mount Brackets W/ Controller Mount
  • N15 SAP Delete Plate W/ Gasket
  • NGK #7415 Spark Plugs
  • OE CSL Clutch Fan Delete Nut
  • Radium Engineering Catch Can W/ Vibrant Performance Hoses And HPS Embossed Clamps
  • Radium Engineering Catch Can Petcock Drain
  • Radium Engineering Low-Profile Swivel 10AN Fitting (For Catch Can)
  • Radium Engineering Fuel Rail W/ Radium Fuel Pressure Gauge and "OEM Style" Fuel Pulse Damper
  • Rogue Engineering 4pc Race Pulley Kit
  • SAP/EGR Delete
  • SPAL 16" Fan
  • Taylor Extended Negative Battery Cable
  • Turner Motorsport IAT Relocation Sensor Harness
  • Vibrant Performance ExtremeShield 1200 Flex Tubing For Coolant Supply HPS Hose/OEM Vent Hose
  • Walbro F9000274 E85 Fuel Pump W/ Radium Fuel Pump Install Kit And New PTFE Hose
  • Windshield Washer System Delete
Braking
  • Hard Motorsports Race Brake Duct Kit W/ Back Plates
Wheels
  • Apex Racing Silver ARC8 18x9.5 ET35 (Square)
    --Apex Racing Black Center Caps
  • Bridgestone RE-71R 265/35R18 Tires (Square)
  • DMC 10mm Front Wheel Spacers
  • Bimmerworld 20mm Rear Spacers
  • Project Kics Iconix R40 Locking Lug Nuts (Black)
  • PSDesigns Titanium 84mm Wheel Studs
Weight Savings
Current Weight 2845 lbs. without driver and 1/2 tank 4/3/2019
  • Airbags Removed
  • Apex Racing Wheels
  • BimmerWorld Straight Pipe Race Exhaust
  • Clutch Fan Removed
  • Dash Ducting Removed
  • Glovebox Deleted
  • Hard Motorsport Poly Rear Quarter Windows
  • Hard Motorsport Side Dash Vent Delete Panels
  • HVAC System Removed (Heat And A/C)
  • JVT Headers
  • Rennline Battery Cage (3 lbs.)
  • E-Brake Handbrake Assembly Removed (Cables and other components still installed)
  • PSDesigns Titanium Wheel Studs
  • RHR Performance Radio Delete/Center Vent Delete Panel
  • SAP/EGR System Removed
  • Sparco Evo 2 Seats
  • Sparco R 383 Steering Wheel Setup
  • Stereo System Removed
  • Stereo Wiring Harness Removed
  • Stock Interior Removed (Seats, Panels, Headliner, Cabin/Trunk Carpet, Etc.)
  • Sunroof Assembly Replaced W/ S2R Fiberglass Panel
  • Washer Fluid System Removed
Parts Included (Not Installed)
  • AKG Aluminum Flex Shaft Coupler (BNIB)
  • AKG Delrin Brake Pedal Bushing (BNIB)
  • BC Racing Stock Endlinks (Used)
  • Brey Kraus Seat Belt Clips Mounts (BNIB)
  • Bunch Of Seals and other things (BNIB)
  • CPV O-Ring (BNIB)
  • Hard Motorsport Front/Rear Retractable Tow Hooks (BNIB)
  • Hard Motorsport Rear Poly Quarter Window Spare Brackets (BNIB)
  • Hard Motorsport Rear Seat Bulkhead Filler Panel
  • LiquiMoly 10w60 Synthoil Race Tech GT1 (BNIB)
  • Mahle-Behr Oil Filter Kit (BNIB)
  • Matte Black Front Grills (Used)
  • Misc Hardware (Used)
  • MTC Magnetic Oil Drain Plug (BNIB)
  • N15 Hood Vents (BNIB)
  • OEM Belt Mount Springs (BNIB)
  • OEM Chrome Front Grills (BNIB)
  • OEM Door Handle Seals Driver/Passenger (BNIB)
  • OEM Door Sills (Used)
  • OEM Drain Plug Plug Seals (Oil Pan) (BNIB)
  • OEM E-Brake Assembly (Used)
  • OEM Fuel Level Sender Unit (Used)
  • OEM Harmon Kardon Audio Amp (Used)
  • OEM Injector O-Ring Set (BNIB)
  • OEM Quarter Windows With Seals (Used)
  • OEM Seat Slider Bolt Caps (BNIB)
  • OEM Tank Filler Pot W/ Neck Filler Hose (BNIB)
  • OEM Valve Cover Vent Hose (BNIB)
  • OEM Window Switches (Used)
  • OEM YAW Sensor (Used)
  • Project Kics Iconix R40 Non-Locking Lug Nuts (QTY. 4 Nuts) (Black) (BNIB)
  • Quik-Latch Bumper Kit (Black (BNIB)
  • Radium Fuel Rail Spare Parts (BNIB)
  • Rennline Remote Battery Cable Pull Kit (BNIB)
  • Stock Parcel Shelf Cover (Used)
  • Stock Parcel Shelf Vent Trim (Used)
  • Stock Rear Carpet (Used)
  • Stock Swaybars (Used)
  • Stock Trunk Plastic Trim Panels (Used)
  • VP Racing E85 Fuel Jugs With Filler Hoses (x2) (BNIB)
  • Wiseco Valve Shim Kit With Tools (BNIB)
  • Zealous Manufacturing Seat Bracket Beauty Hardware (BNIB)
DIY/Install Videos
      08-23-2020, 01:28 PM   #2
Andrew
Moderator
Andrew's Avatar
429
Drives: E46 M3 / E92 M3
2003 BMW M3  [0.00]
2008 BMW M3  [0.00]
mcmahonbj Sad to see this one go. Hope it goes to a good owner.
[Track] 03 AW/CIN 6MT E46 M3
[Street] 08 AW/FR 6MT E92 M3
[Tow/Overland] 23 Toyota Tundra HV TRD Off-Road
      08-23-2020, 01:35 PM   #3
mcmahonbj
Drives: 2004 BMW M3
Thanks Andrew I appreciate your help with things along the way also!!!!
      08-24-2020, 11:23 AM   #4
mcmahonbj
Drives: 2004 BMW M3
More photos added to my Flickr
      08-24-2020, 09:45 PM   #5
dangyi
Drives: 2013 M3
The car looks really nice! Just curious, why don't you add a cage with so many track preparations?
      08-25-2020, 08:31 PM   #6
mcmahonbj
Drives: 2004 BMW M3
send over 3k and I will. You realize cars take time to build and modify.
      08-27-2020, 01:20 PM   #7
dangyi
Drives: 2013 M3
Sorry I was not talking about it should have a cage. I'm just wondering how it is necessary if no wheel-to-wheel race is performed.
      08-28-2020, 04:53 PM   #8
mcmahonbj
Drives: 2004 BMW M3
its necessary for a future owner to do if they are going to track it.
      09-06-2020, 03:18 PM   #9
mcmahonbj
Drives: 2004 BMW M3
bump ttt
      09-29-2020, 01:46 PM   #10
dangyi
Drives: 2013 M3
Is it sold?
      10-17-2020, 01:37 PM   #11
mcmahonbj
Drives: 2004 BMW M3
SOLD
