      10-10-2023, 10:15 PM   #1
chocdog
Drives: F22 M240 (G42 M240 in build)
Any G series with 18” or 19” with space saver / donut / temporary spare?
Does anyone know of any G series cars that comes with a space saver (18” or 19”)? Preferably steel.
I want to put together a space saver spare for my G42 M240.
Therefore I am looking to identify a steel wheel (due to cost) in 18” or 19” to suit. Therefore it needs to suit: PCD = 5X112mm & CB = 66.6mm.
Needs to be 3.5”-4.5” wide to suite up to 155 tyre width. Not fussed by offset at this stage.
If I can identify a G series car, I should then be able to find one at a car wrecker here in Australia easily I did this for my F22 M240 with a steel E series X5 18” wheel. Unfortunately G series cars have moved from a 120mm PCD to a 112mm PCD… (I know in the US and UK there are a few companies selling kits at a reasonable price; but not in Australia).
So far I have only found the following G series by trolling parts lists:
PN36115A3E078 / 36112470249: 5BX19 ET:-2 19” Alloy wheel with 155/80R19 tyre for X5, X6, X7 and 7 series
Just the wheel for this is 36116880744.
Any help would be appreciated!
      10-10-2023, 11:31 PM   #2
alex2364
alex2364's Avatar
2914
Drives: 2020 M4 ZCP / 2023 X3 M40i
2020 BMW M4  [10.00]
2023 BMW X3 M40i  [10.00]
G01/02 X3/X4 has optional space saver spare.
chocdog18.50
      10-11-2023, 09:24 AM   #3
ppointer
Drives: '01 Z3M, '12 335is, '22 540i
2012 BMW 335i  [5.25]
2012 BMW 335is  [5.00]
2008 Infiniti QX56  [0.00]
1967 Chevrolet Corv ...  [10.00]
2001 M Roadster  [10.00]
2022 BMW 540i  [0.75]
2009 528i  [9.50]
I have a G30 that I ordered with the spare setup. Is that what you are looking for?
chocdog18.50
      10-11-2023, 04:07 PM   #4
chocdog
Thanks awesome info, cheers! Hadnt checked X3/X4. PNs and details are:
36116863416 EMERGENCY WHEEL, LIGHT ALLOY 4BX18 ET:-1
36112420121 same but with 135/80R18 tyre
This will be perfect if I can track one down. Being 4" I can get a donut tyre in a suitable profile for the G42 M240 (eg T145/70R18).
Unfortunately the X5 spare wheel is 5" and there is no donut tyre in a suitable profile for the G42 M240.
Cheers again for the lead.
      10-11-2023, 04:11 PM   #5
chocdog
Indeed it is! Looks like the 5 series uses the same space saver as the X3/X4 PN that I listed above.
Cheers for the lead.
ppointer750.00
      10-20-2023, 08:00 AM   #6
Bc2005
Drives: 2021 M340i
The optional spare tire on the G20 was a reasonably priced option ($250 for tire, jack, etc), but I think I only ever saw about two cars on the lot that had it. They used a shelf that took up about 1/2 the trunk vertically and 2/3rds or more from side to side. Most folks thought that was too much space to lose.
      10-21-2023, 06:35 PM   #7
chocdog
Its proving that sourcing a G series 18/19” ~4” wide space saver spare in Australia is not easily. The OE 19” is about AUD1000 + a different tyre is required. Wreckers (dismantlers) in Aus don’t seem to be coming across them; so not really available at a realistic price.
But Mercedes have a couple of options. The ML (& GLE) SUV’s from the W163, W164 and W166 series (~97-19) came with a 18” steel 4” wide space saver with the required specs (PCD = 5X112mm & CB = 66.6mm.)
The Mercedes part numbers are:
A1634011102 = 18X4” ET00
A1644000002 = 18X4” ET40
Either offset should suit (since wheel width is only 4”).
Note this website lists all vehicles with PCD = 5X112mm & CB = 66.6mm: https://www.wheelfitment.eu/PCD/5x112%20/66.6.html
