      12-28-2016, 08:46 AM   #1
Bsaint
BsaintMedia.com
Bsaint's Avatar
Drives: Collection of German
Arrow My LS6 E36 M3 Burnout/Drift
Nothing crazy just a little year end burnout and shot from my larger video of me doing a little U-Turn.
IG @Bsaintmedia
YouTube << Subscribe |
ShocknAwe3238.50
      12-28-2016, 10:15 AM   #2
buddalun
buddalun's Avatar
Drives: 911 x 2, Tesla M3P & MYP
Where is your hood?
      12-28-2016, 10:24 AM   #3
Bsaint
BsaintMedia.com
Bsaint's Avatar
Originally Posted by buddalun View Post
Where is your hood?
In my garage, but glad it bothers you
IG @Bsaintmedia
      12-28-2016, 10:27 AM   #4
buddalun
buddalun's Avatar
Nope, just curios if it still fits with the LS swap; simmer down.
Dackelone10621.50
      12-28-2016, 10:42 AM   #5
Unknown_Car
Unknown_Car's Avatar
Drives: Few and diffrent
Looks nice.
JB4 Tune, MHD backend flash, E85
VRSF 7" Intercooler, BMS OCC
VRSF CP & TIAL 50mm BOV, BMP PI
DocRace 6266 single turbo.
      12-28-2016, 10:45 AM   #6
Bsaint
BsaintMedia.com
Bsaint's Avatar
Curious*
and yes of course it does, actually sits lower and further back and weighs less than the s52, and I'm not the one upset lol
it also runs on the tears of purists
Originally Posted by Roma_335i View Post
Looks nice.
thanks man.
IG @Bsaintmedia
      12-28-2016, 01:08 PM   #7
ShocknAwe
1Addict
ShocknAwe's Avatar
3239
Drives: E82 Mutt, M57 Truck
Awesome. Do you have a build thread for that car any where?
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      12-28-2016, 01:35 PM   #8
Bsaint
BsaintMedia.com
Bsaint's Avatar
Thanks man!
I started one back in 2011 on bimmerforums, but after it taking 3 more years I kind didn't update it at all specially considering it was nothing ground breaking at the time and the swaps have been done and documented fairly extensively. Also most of the links are dead thanks to imageshack being bought out and sold.
However I'd be happy to answer any specific question if you have any.
Typical ones are what kit, whats done to the motor, what trans etc.
Kit was Vorshlag Alpha kit, Solid front subframe mount, vorshalg longtube headers, no cats, vorshlag drive shaft into stock M3 diff 3.23 lsd rear.
Motor is fairly stock, cam only eps 234/246. I will be boosting it soon.
Trans is a t56 from an 02 GTO paired with LS7 clutch and flywheel.
Also just made 422whp and car weighs 2,800 lbs
IG @Bsaintmedia
      12-28-2016, 06:16 PM   #9
FD3S
Drives: BMW Z4M
I have a silly question: How do you do the burn out?
      12-28-2016, 06:54 PM   #10
last1left
last1left's Avatar
175
Drives: e92 M3
Damn ruthless fun
      12-29-2016, 02:01 AM   #11
bmwcoder
bmwcoder's Avatar
Drives: E46 + Macan S
crqzy M3
      12-29-2016, 09:20 AM   #12
Bsaint
BsaintMedia.com
Bsaint's Avatar
hahaha well I guess it's not silly if you've never tried, but every car is different. Mine will do one in first or second just from flooring it and holding the brake, but for these I rev to about 2-3k drop clutch in first gear then quickly stand on the brake. While holding the brake I feather the throttle between 3-4k and let them spin. Then when I feel like I've had enough just let off the brake and ride out the throttle make sure not to over rev. You could shift into second or third if you want to really smoke them. Obviously an auto car or a car with traction control is different you are going to want to turn off everything and just hold the brake and gas slowly feathering the brake so the rear can spin.
Originally Posted by last1left View Post
Damn ruthless fun
That it is! haha thanks man
Originally Posted by bmwcoder View Post
crqzy M3
appreciate it!
it's pretty quick, but never enough.
Run against a GTR
IG @Bsaintmedia
      12-29-2016, 02:39 PM   #13
FD3S
Drives: BMW Z4M
Saint thank for your helpful answer.
You hold the brake with your left foot and the gas pedal with the right?
Also what happens with the rear brakes?
      12-29-2016, 03:07 PM   #14
Dekansnowman
Dekansnowman's Avatar
83
Drives: 2011 335i Sedan Space Grey
I've done my share of swaps with 240s and such, and the tricky part was always the wiring. Did you sent engine and donor harness to be done, or just buy a plug and play harness ready to go? Once I switched to those, man everything got easier.
      12-29-2016, 03:30 PM   #15
Bsaint
BsaintMedia.com
Bsaint's Avatar
Yes sir,
and as you know your front brakes do about 80% of the braking that's typically why they are bigger. Your front should hold it enough to either lock up the front wheels and still apply bits of pressure to the rear which yes is not exactly good for your rear brakes, but its kind of how it is. The only way to apply just front brakes and leave the rear off is to install a line lock, typically drag racers use this who need to burnout more. But for the occasional burnout it's not needed.
There wasn't really a plug and play harness at the time and I don't believe there is 100% one now
I sold the s52 and trans/wiring harness from the original setup, because everything is controlled through the GM ecu and tuned through it using HPtuners it was a matter of wiring the BMW into the GM computer. Thankfully I did not tackle this as I do not have the patients for it lol. If I was to do it again I would probably just look into a holley dominator efi, specially for boost applications. I'll probably switch to one down the road though.
IG @Bsaintmedia
      12-29-2016, 03:42 PM   #16
RABAUKE
4669
Drives: Porsche 993, 2014 MB GLK
They slip against the torque, the front brakes hold as they don't get power. It takes a bit of practice as you're trying to just brake enough to keep from moving forward while the rear spins like a demon.
      12-29-2016, 04:14 PM   #17
FD3S
Drives: BMW Z4M
Thank you guys for your answers.
      12-29-2016, 04:20 PM   #18
Bsaint
BsaintMedia.com
Bsaint's Avatar
pretty much. haha
IG @Bsaintmedia
      12-29-2016, 04:22 PM   #19
Bsaint
BsaintMedia.com
Bsaint's Avatar
No problem! now go video some burnouts and post them for us to watch haha
IG @Bsaintmedia
