      10-09-2023, 02:20 PM   #1
Roth517
Roth517's Avatar
446
Drives: 2022 M4C xDrive
FS: 2005 M3 SMG slicktop 22k miles
2005 BMW M3 SMG Silver-Grey slicktop (non-sunroof) for sale. 22,050 miles.
Two owners in Louisiana before I bought it. Originally ordered with rear spoiler delete, power and heated seats (but not the Premium Package, hence no sunroof), xenon headlights, harman/kardon sound, and SMG. Built 10/06/04.
After purchasing it in April, I sent it directly to Enthusiast Auto Group (EAG) in Cincinnati for a full inspection and service. EAG performed the Inspection II service (oil change, valve adjustment, all fluids changed, spark plugs, filters, and a complete vehicle inspection ($1,595); changed the engine accessory belts ($238); timing chain tensioner seal ring ($73); rear trailing arm bushings ($535); rear differential pinion seal and differential mounts ($1,162); new front struts ($1,292); rear shocks ($641); and they made cosmetic repairs (steering wheel trim and driver's door arm rest trim ($990). EAG also inspected the subframe and VANOS, which are both good. Total EAG service: $7,156. (See service receipts in pics.) I also have the EAG inspection papers showing everything they found and what's been repaired (nearly everything; see below for the few known flaws).
I then spent over $1,100 in cosmetic repairs (various badges, gas cap, fuel filler liner, rubber trim, plastic covers, trunk lip spoiler, side marker turn signals, etc.).
Only modifications by previous owners: AFE aftermarket air filter and Pagid drilled rotors (stock, OEM calipers remain). I installed IND painted reflectors.
Known flaws: tires are old and should be replaced; the A and C pillar trim needs to be replaced; windshield washer pump inoperable; lower horn inoperable; glovebox flashlight inoperable.
No door dings or dents. 19" polished aluminum wheels are in perfect condition with zero curb rash. Only a few stone chips on the front end. Three small scratches behind right rear wheel. Only hand washed by me and detailed with Zaino products. Clean Michigan title in hand. Selling only because I recently found a similar, low mileage M3 in a more preferred color. Clean CarFax. Car looks even better in person and will not disappoint.
Current: 2022 M4C xDrive Rosso Corsa; 2005 M3 Imola Red ; 2018 440i Mineral Grey
Past: 2017 M4C; 2013 Audi RS5; 2011 Audi A5 S-Line; 2008 335i (x2); 2004 330Ci (x2); 2000 323Ci
      10-09-2023, 02:29 PM   #2
Roth517
Roth517's Avatar
446
Exterior pics
      10-09-2023, 02:38 PM   #3
Roth517
Roth517's Avatar
446
Interior pics
      10-09-2023, 02:45 PM   #4
Roth517
Roth517's Avatar
446
Various
      10-14-2023, 09:30 PM   #5
anthemavm
anthemavm's Avatar
578
Drives: X3MC
Wow, this is beautiful.
      10-15-2023, 10:09 AM   #6
Roth517
Roth517's Avatar
446
Thank you! Needs a good home.
      10-23-2023, 07:44 PM   #7
Imolaem3
Drives: 2016 BMW M4 GTS 2011 BMW 1M
Sent you a PM
      10-23-2023, 08:02 PM   #8
Roth517
Roth517's Avatar
446
Originally Posted by Imolaem3 View Post
Sent you a PM
Just texted you.
      01-17-2024, 07:13 PM   #9
Roth517
Roth517's Avatar
446
Sent you a PM
This guy is a joke. Didn't respond to texts. Did this to another guy trying to sell on here. Beware...
      01-17-2024, 07:17 PM   #10
Roth517
Roth517's Avatar
446
Edited
      01-21-2024, 01:15 PM   #11
///Marecki
Drives: 06 M3 ZCP
Incredible car GLWS
Roth517446.00
      02-21-2024, 08:15 PM   #12
Roth517
Roth517's Avatar
446
Edited
      02-22-2024, 09:09 AM   #13
Roth517
Roth517's Avatar
446
Bring a Trailer bound...
      04-05-2024, 10:25 PM   #14
M3ZCPNYC
Drives: M3
This sell?
      04-17-2024, 09:04 AM   #15
Roth517
Roth517's Avatar
446
Originally Posted by M3ZCPNYC View Post
This sell?
Yep.
