      03-27-2023, 09:06 PM   #1
adorsa_e46m3
Drives: 2017 M2 Performance Edition
FS: 2001 E46 M3 w/ 73k miles
Hi Everyone - I am selling a 2001 BMW E46 M3 with 73,000 miles. True Manual transmission, jet black exterior, black interior, clean title. This car drives amazing, and I am only selling because I am buying an M2.
I bought the car in late 2018 with ~58K miles. The big 3 have all been performed professionally with receipts under my ownership. I have also replaced/upgraded the cooling system, fuel system, oil pump, suspension, clutch (in last few months), most bushings and lots of sensors. Some other notable upgrades/replacements include Brembo BBK, KW V2, Apex EC-7 wheels on Michelin PS4S, Bav sound speaker, Avin Avant 4 head unit, LED taillight conversion, Autosolutions SSK with 20% throw reduction, Alcantara/leather steering wheel and much more. The complete list is included below.
The car has always been stored in a garage and comes with 2 keys. Paint is in overall good condition with some minor flaws from age/use. Interior condition is great. The original calipers, brake pads, shifter and radio come with the car.
Every single upgrade/maintenance item has a receipt to go along with it. The car is SMOG compliant, and I am happy to go get that done prior to finalizing sale.
I am asking $29,000. The car is located in San Francisco, CA (zip: 94116). I am willing to ship. Please feel free to reach out with questions at 317-503-0630.
VIN: WBSBL93481JR10650
Wheels:
• Apex EC7 wheels - 18x9 ET 31 front - 18x10 ET 25 rear
• Michelen PS4S tires - 245/40/18 front, 275/35/18 rear
Major Service (with receipt):
• Complete vanos refresh @ 60K miles
• Subframe reinforcement @ 62k miles
• Rod bearing @ 67k miles
• Inspection 2 - oil change, Diff fluid change, trans fluid change, valve adjustment, new spark plugs, valve cover gasket
• Oil system refresh (All OEM): Oil pump, Oil pan Gasket, Oil pan cone gasket, oil level sensor, Oil pressure sensor, Oil pump pickup O-ring
• Deflection tensioner and drive belts, water pump pulley, tensioner pulley, idler pulley, hydraulic tensioner, AC ebelt, Accessory Belt
• Cooling system: Thermostat and thermostat O-Ring, water pump, gasket and O-rings, expansion tank & hose, ECS exact fit water pipe connecting hose, coolant level sensor, ECS tuning silicone radiator hose kit
• Fuel system: Fuel filter, Fuel pump, Fuel relay @ 73k miles
• Clutch & Flywheel replaced @ 73K miles (in Feb 2023): Clutch, pivot pin, flywheel, pivot fork, guide sleeve, pilot bearing, crank seal, transmission fluid (redline)
• Replaced diff fluid with redline 5W140
• Very regular oil changes
Bushings replaced:
• Driveshaft Guibo flex disc
• Center support bearing
• Transmission mounts
•Rear trailing arm bushings
• Rear control arm bushings
• Powerflex Diff bushings & diff bolts
• Exhaust hanger bushing center section
• Motor mount
• Front control arm bushing
• Brake and clutch pedal bushing
Interior upgrades:
• Alcantara/leather steering wheel with red center line
• Bavsound speakers
• OEM shift boot & ZHP shift nob
• Dynavin double din center console insert
• Avin Avant 4 head unit - PX6, 4 GB ram, 64GB ROM, 6-core CPU, Android 10, optional IBUS adapter, wireless CarPlay (still have original radio)
• New AC center vents
• New Heater blower Motor
• Turner Pedal covers
• Grey interior conversion to black
Suspension:
• KW V2
• OE strut mounts
• Rogue Engineering rear shock mounts
• Garagistic strut tower reinforcement plate
• Garagistic Rear spring perch reinforcement
• Tie Rod replacement kit
Exterior upgrades:
• OEM LED tail lights, LED taillight adapter & Properly coded LCM
• IND paint match reflectors
• OEM BMW Orange Turn signals
• Rear BMW roundel
Sensors replaced:
• Front wheel speed sensors
• MAF sensor
• All pre-cat and post-cat 02 Sensors
• EGT Sensor
• Exhaust Camshaft position sensor
• Turner IAT sensor relocation & new IAT sensor
• Coolant level sensor (previously mentioned)
• Oil Pressure Sensor (previously mentioned)
• Oil level sensor (previously mentioned)
Brakes:
• Buildjournal BBK (I still have original calipers)
• 996 rear Brembo brake calipers (rebuil with new pistons, seals, dust covers and other hardware)
• OEM BMW 345x28 competition/ZCP/CSL rotors
• Euro floating rear rotors
• Rally road adapter brackets & braided lines
• Motul RBF 600 brake fluid
• Akebono performance ultra premium ceramic pads
Other upgrades/replacements:
• CPV & o-ring
• AutoSolutions SSK (autocross, 20%, extra 10mm of height) still
have original shifter
• Crank case vent hose
• Hood and Trunk Gas Struts
• AGM battery
      03-27-2023, 09:07 PM   #2
adorsa_e46m3
Adding more pictures
      03-28-2023, 09:57 PM   #3
nochain19
Drives: F80 YMB
What exhaust is on the car?
      04-05-2023, 06:08 PM   #4
Gotfuel
Gotfuel's Avatar
17
Drives: Trek Madone
DM’d
Current:
16 M2, LBB DCT. 14 335 Sport Superman Spec, 06 Avant 6sp Many Things, 06 Range Rover Sport Supercharged
Past: 13 RS5 Coupe, 04 M3 Vert, 95 URS6, MK6 GTI, 69 Chevelle Copo 427 clone, many Fox Mustangs
      04-07-2023, 04:19 PM   #5
adorsa_e46m3
OEM
      05-07-2023, 06:19 PM   #6
adorsa_e46m3
Bump
      06-01-2023, 04:33 PM   #7
adorsa_e46m3
bump. price reduced to $29K
      06-02-2023, 06:57 AM   #8
N55e82Simon
N55e82Simon's Avatar
157
Drives: BMW 135i
2011 bmw 135i  [9.33]
Very clean and well documented. Glws
      06-09-2023, 05:14 PM   #9
adorsa_e46m3
pending sale
