      11-17-2022, 02:30 PM   #1
Csanter
Csanter's Avatar
Drives: 02 e46 M3, 83 One Ten, 22 P2,
2002 TiAg Slicktop m3 Cloth SMG full records
USD 23,500.00
Good Day all,
Im looking to sell my e46 M3 which has been great to me. Ive owned it since 2015 and enjoyed every mile. Regular maintenance was habitually done with 5,000mi oil changes and 15,000mile valve adjustments, brake fluid changes biennially or sooner if needed, diff fluid changes in conjunction with valve adjustments, and a transmission fluid change after I purchased the car. I will detail records below. At 155,000~ miles it has its normal wear, there are no major issues or any drivability problems. I currently enjoy it on the weekends and have been taking it out less frequently then the first few years of ownership. The interior is in excellent shape with no tears, splits or stains on the Factory Impluse Cloth seats. There is a slight dimming of pixels on the odo but it only effects partial dights and has not changed since it happened two years ago. The carfax lists a Damage report, the previous owner did say the front bumper was repainted due to a scrape and the car was not in an accident, Autocheck is clear. I have both of those documents for anyone interested.
Year: 2002
TiAg / Impluse Cloth
Slicktop
154,669mi
SMG
1 of 69 in this configuration
Subframe reinforcement by Kassel Performance in February of this year
Rod Bearing done by BMW 11/04, then done again by Motorcepts 6/2019 at 140,000miles
Vanos Lock down completed 11/2019 146k miles
SMG Pump and Gear Selector replaced with Burkhart Pump and OEM Gear Selector 11/2019 145,183mi by TKX Performance
Asking $23,500
Located in Northern Virginia
Rod Bearings 11/29/04 Mileage 27,456
Airbag recall for Module 12/17/15 107960
Coolant system overhaul 01/12/2017 114,000mi
Airbag recall for Drivers side Airbag 08/15/17 124424mi
Suspension refresh Front control arms, RTABS and limiters 3/9/2018 131,000mi
Engine, Transmission, Flex Disc 6/8/2019 140,000mi
Rod Bearings 6/8/2019 140,000mi
Valve adjustment 11/02/2019 145,000mi
SMG Pump Motor Replaced Burkhart Unit, SMG Temp Sensor Replaced, Gear Selector Sensor Replaced, Burkhart SMG Fluid 11/04/2019 145,183mi
Vanos refresh; Upper Chain Guide, Beisan Oil Pump Disc, Rattle Repair Kit, Seals Repair Kit, Solenoid Pack, Sealing Plate, Lang Racing Cam Gear Bolt Set. 11/28/2019 146,000mi
Interior A,B,C Pillars replaced, cupholders. 05/27/2021 152,000mi
Here is a Link to the Google drive full of images: https://drive.google.com/drive/folde...wI?usp=sharing
Thanks
Chad
      07-17-2023, 09:22 PM   #2
Roadie432
Drives: M3
Is this still available?
