08-31-2007, 03:09 PM | #1 |
Administrator
41256
Rep 21,247
Tutorial: Photographing moving vehicles
Found this a good read for some guidelines/tips:
http://www.morguefile.com/archive/cl....php?lesson=12 |
08-31-2007, 06:41 PM | #2 |
Rep 45
FWIW, sticking stuff on the outside of your car will get the attention of the police. One of our guys heading down to Bimmerfest last spring had his camera stuck on the side of his car with a suction cup mount. The CHP pulled him over and told him to remove it.
01-29-2008, 05:47 AM | #4 |
Z4M CSL
31
Rep 173
You don't need to mount your camera to the car to get shots like that. You can just as easily hand-hold and shoot through an open window of the travelling car, or out the hatch.
The only advantage of mounting the camera, is that you could mount it lower on the car than you could reach, and get a lower perspective shot.
01-29-2008, 05:53 AM | #5 |
The Law.
301
Rep 14,283
For rig shots, the car should not even be on let alone driving 50+mph on the freeway. If your recording video, thats a whole other subject. But as far rig shots go, the engine should not be on because the vibration will cause the rig/camera to shake. Also, the car should probably be moving less then 5mph. Anymore is just overkill imo.
01-29-2008, 07:46 AM | #6 |
Rep 101
Just learn Photoshop!
Apple's market share is bigger than BMW's or Mercedes's or Porsche's in the automotive market. What's wrong with being BMW or Mercedes?
Join us: http://www.autofriendship.com |
12-12-2008, 11:08 AM | #8 |
Rep 1,334
Drives: 335i E92 Montego Blue
Thanks for posting, thats great!
01-25-2009, 08:48 PM | #9 |
Rep 959
the link in first post isn't working for me
01-26-2009, 09:35 PM | #10 | |
Night Sh1ft
462
Rep 3,079
Drives: F95 X5MC LCI
then again, if you dont have open roads, you cant be using a rig anyways...so I guess, +2
"Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson |
02-02-2009, 07:51 PM | #11 |
Rep 161
Here are some more rig pics...
http://www.blog.spoongraphics.co.uk/...tography-shots And a small write up done by the guy that took em... http://mattwatkinson.com/blog/?p=60 |
03-29-2009, 01:48 AM | #12 |
Bootleggin' 'n Gunrunnin'
137
Rep 2,372
The original link is busted. Here is the corrected link:
http://www.morguefile.com/docs/Class...oving_Vehicles
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
07-03-2009, 08:05 AM | #13 |
HALA MADRID!
940
Rep 2,879
what shutter speed are you guys using?
I have a 17-50mm 2.8, and been trying to use 1/25 and shots wont come right. Any suggestions?
F87 M2 Competition, Sunset Orange, Exc, DCT. **SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015 **SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. |
07-14-2009, 04:13 PM | #14 | |
Rep 6
I'm new to the forums, but have been into photography for a while. It depends on what focal range you're shooting, but a general rule to follow, is 1/<focal range> at minimum. So..if you're shooting at 17mm, you should be ok but at 50mm your shutter isn't fast enough. To compound the issue further, if you're using a crop body sensor, you need to take your focal range times your crop. For instance. A Canon 50D has a sensor crop size of 1.6. So with a standard EF lens at 17mm, you're actually shooting at an effective range of 27.2mm, so your shutter still isn't fast enough. This doesn't take into account shooting from a moving car either, so you will want even faster for that. Might have to sacrifice some noise and bump up your ISO. |
08-20-2009, 01:23 AM | #15 |
Is twizted... But has no real bunny
Rep 247
I have never handheld a rolling shot using anything slower than 1/60th shutter speed... 1/25th is too long and the image becomes blurry and over exposed(depending on aperture settings)
here are a couple of mine at 1/60th handheld, out a window of a moving car at about 40mph. Edit: I also shoot with shutter priority, I believe it is Tv mode on the canon I use, I don't want to adjust aperture and shutter when I shoot my rollers due to the fact that I shoot in the morning or evening and the light is always changing. Now I am not saying you cannot do rolling shots on full manual mode, but I am suggesting that you save yourself some time and get in more shots instead of messing with the aperture and shutter settings after every 5-10 shots.
That bathroom is made of lead... Time can't get in there...
08-28-2009, 02:00 AM | #16 |
BEEP BEEP
Rep 96
TV MODE, AI SERVO, keep it 1/60 and up.
Sit in the rear passenger of a car, and stick your head out with the camera. Be safe.
2003 911 Turbo | K24/18G | Bone Stock Exterior |
01-20-2010, 09:49 PM | #18 |
Image Guru
Rep 9
Great Thread!
09-24-2010, 08:23 AM | #20 |
471
Rep 6,798
