      04-17-2024, 04:15 PM   #1
ctdriver86
Drives: e46 m3
FS: 2003 M3 manual drivers car
USD 21,000.00
I have an opportunity to build a dad wagon. I'm not sure if I'll be able to continue enjoying the car for the purpose I've built it for. I have a turn key trackable street car. It's built to enjoy in the street and track. For anyone seriously interested. Message me. It's for someone who knows and has built an e46 m3. From engine to subframe.$21k obo. Motivated to sell to the next person who will enjoy the car. I enjoy driving this car. I'm hoping it goes to someone that will appreciate the work I've put in and continue to enjoy its capabilities at the track. It's a drivers car. I've removed the ohlins dedicated suspension for new bilstein b12 pro kit and recaro seats for sport comfy m6 seats to lower the price. Making it a great foundation for someone to build their own street/clubsport car or into a track car or guilt free daily. I'm currently still driving the car and enjoying it since I've come so far with the car and it just needs to be driven and enjoyed. I've owned this car for 7 years since buying it at 155k. But with a kid coming, I'm looking into building an s54 wagon. Feel free to email me for any questions. Thanks!
Ctdriver86@gmail.com
2003.5 original 6 speed with mk60 abs unit
217k On chassis, no rust
Engine
90k Mile s54 Purchased in April 2022, leak down tested at 0-3%
- head removed and rebuilt by Engine Supply in Santa Ana with OEM BMW valve seals (Using OE Elring Headgasket)
- WPC Treated ACL Std size Rod Bearings, Oil Pump Gears, Rocker Arm Shafts (intake and exhaust), intake (Also Cryo treated) and exhaust hubs
- Full Beisan Systems Vanos Seal Kit with BS Oil Pump Disk and Heavy Duty Timing Chain Guide
- New OEM BMW Waterpump
- Bimmerworld Oil Diverter valve with BavAuto High performance Oil Filter Housing Gasket
- Installed February 2023. Engine Currently has 8k miles with about 5 Track Days. Engine Runs great and does not consume any oil.
- Rogue Engineering Power pulley (water pump and Power steering)
- Koyo Full Aluminum Radiator (80% distilled water, 20% BMW Coolant and water wetter)
- N15 Design Electric Fan Mount with Spal 2082 Electric Fan
- D088 Oil Cooler
- Build Journal Aluminum Radiator Duct
Subframe reinforcement
PSDesign plates
vincebar top reinforcement
stitch welded rear RACP and wheel wells.
Undercarriage seam sealed and painted SEM coating
Superpro offset bushing for upper spring arm for additional camber
Brakes
- Stock brakes with Stainless steel brake lines
- Endless ME22 Brake pads
- Endless RF650 brake fluid (pads are a few months old, fluid flushed in June 2023)
Transmission opened, inspected and resealed.
Advanced Auto Fabrication full adjustable chassis mount shifter
Shifter detent springs replaced
Suspension/Steering
Bilstein B12 Pro Kit (Newly installed)
OEM Differential Bushings/ Rogue Front Diff Bushings (Very little NVH)
AKG Solid Subframe Bushings
Hotchkiss FR Sway Bar
Zhp 712 Steering rack
Sunroof removed, Painted Sunroof Delete with Slicktop headliner in Alcantara suede with A/B/C Pillars
Street faction rear seat delete aluminum
Bavsound Speakes
Matt Black Cubed Trim
Steering wheel delete Trim
Custom Cruise control Relocation
Race Door Cards
Misc:
Resonated section 1 and 2 (uuc or borla)
Remus Exhaust
      04-18-2024, 12:22 PM   #2
Sthbaysam
Drives: E92/E46 M3
Bump for a great seller and well sorted car! 🤙🏽
