09-24-2014, 11:06 PM | #573 |
11818
Rep 23,187
Having a rubbing issue up front still with the hankook. not sure if its related to having more aggressive pads now and compressing the front more under braking reducing my ride height and rubbing or what but decided to call it a season a little early and am going to go to work on my off season projects for the car. only got 2.5 days out of the c51 or about 18-20 heat cycles, some of which were ran after i corded.
As of now i plan to scrape and remove sound deadening, thin and pull wiring, address the vanos bolts, track down a small oil leak im having, pull and massage the front fenders to allow 280-650-18 tires. If money is okay i may also do a 3.91 ring and pinion swap, fabricate a front splitter that will also replace the plastic undertray, apr rear wing, finish the front half of the cage and whatever else i can to lighten the car further. goal is to have it under 2900lbs.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| Last edited by 1MOREMOD; 10-02-2014 at 08:32 PM.. |
10-02-2014, 08:42 PM | #574 |
11818
Rep 23,187
scraping sound deadening is not very fun and neither is chasing wire. ended up getting about 25 lbs of sound material out and about 15 lbs of wiring and random brackets and such out of the car so far. dont think as much is coming out as i expected so will probably end up in the 2925 range this time around.
10-02-2014, 09:03 PM | #575 |
11818
Rep 23,187
few more shots to show some progress. little worried about reassembly of the dash so that everything works still.
10-04-2014, 02:50 AM | #576 |
11818
Rep 23,187
ordered omp wrc wheel and braille battery should get me right at 2900 i think.
10-06-2014, 05:41 AM | #578 |
915
Rep 3,456
Drives: Harrop E90 M3
Pull out the sound deadening behind the dash slacker.
10-06-2014, 08:18 AM | #579 |
11818
Rep 23,187
10-24-2014, 04:37 PM | #581 |
11818
Rep 23,187
finished the sound deadening clean up and rattle canned the interior so all silver again. car is at AR in portland for the vanos bolt replacement/solenoid rebuild, and ran into broken exhaust hub and damaged oil plate. got dr vannos replacements kryo treated and new water pump from turner since it is original part. they also tracked down oil leak to that area just behind thermostat housing there is plug that backs out due to vibration from vanos going bad.
also picked up a set of VAC floor plates to level back out my flooring since everything is out of there. anxious to have it back and reassemble even though no track plans for some time here. Also going to realign with more front camber probably go to -4 and get final weight at same time. hoping sub 2900.
11-11-2014, 07:23 PM | #582 |
11818
Rep 23,187
Car is back and spent today doing reassemble. Braille battery is in, omp wheel, vac floor plates , flushed power steering and tranny. Doing differential tomorrow but need to pick up a 14 mm hex for the drain and fill plugs. Ended up just under 2900 dry and high 2900s with full tank.
Need to heat cycle my maxxis this weekend but unsure it will be doable since high temp is supposed to be 44. |
11-13-2014, 08:20 AM | #583 | |
576
Rep 2,353
11-13-2014, 10:24 AM | #584 |
11818
Rep 23,187
not much to see just new wheel and floor plates. looks little more cleaned up with some of the wiring gone and the interior all painted tiag like the car.
Flying Ace4987.00 |
11-13-2014, 10:29 AM | #585 |
11818
Rep 23,187
here is a shot of the braille 17lb battery. ended up saving 32lbs with this mod. hopefully it works okay for me. car is always on battery tender at home and isnt driven on the street anymore, no plates, insurance or registration. so should be fine.
11-18-2014, 12:38 PM | #586 | |
576
Rep 2,353
11-18-2014, 12:54 PM | #587 |
11818
Rep 23,187
11-18-2014, 01:32 PM | #588 |
576
Rep 2,353
11-22-2014, 08:57 PM | #589 |
746
Rep 1,848
Are you active on M3forum.net? Those guys would enjoy your build.
Looking good. I removed door windows and headlamps this weekend. I also pulled out my passenger seat. Hoping to get below 3000 lbs. I still have sound dampening. I haven't read through your entire build. Do you have CF hood or truck? Our cars appear to be similarly gutted but you're much lighter. |
11-22-2014, 09:05 PM | #590 | |
11818
Rep 23,187
11-22-2014, 09:25 PM | #591 | |
746
Rep 1,848
I have SMG though so that's probably 20 lbs with pump and actuator. I heard sound deadening is about 20 lbs. I'll probably re-install my Evolve CF intake early next year which is another few pounds. I'll post my corner balance specs next time I get it done. What have you done engine wise? I had Evolve Alpha-N-Tune but I had issues with misfires. I took everything back to stock and rebuilt vanos this spring which fixed misfires. I put the CPI headers and BW exhaust back on and got the Epic race tune. Car is running great. I haven't dyno'd the car but I estimate 300 to the wheels. I'll do live dyno tuning when I put the Evolve box back on, looking for 315 whp. I see some guys getting 340-360 with 288/280 cams, CSL style box, stepped headers and high flow exhaust, and TTFS tune. I'd be happy ending up at 340 if I do upgrade cams. I run in NASA TT3, so 3000 lbs and 315 whp with SMG and aero (if I ever get it) would put me at min adjusted wt/hp for that class. |
11-22-2014, 10:04 PM | #592 | |
11818
Rep 23,187
engine has cai, epic tune, pulleys, vannos just was handled this off season, euro header and i figure the same im at about 300 whp. may look to do cams, aero, differential and lightweight flywheel clutch in future.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| Last edited by 1MOREMOD; 11-23-2014 at 11:52 AM.. |
12-27-2014, 03:40 PM | #594 | ||
Rep 1,164
Akra GT4 / MS Stage 2 / MS UDP / BPM Tune / KW CS / H&R Sways / TMS Delrin / ST 380/355 BBK / Cantrell 2.5" Ducts / SR34 Pads / Apex Arc-8 / Hoosier R7's / Mode GT4 Splitter / GT4 Canards / APR GT-250 Wing / Cantrell Half Cage / Recaro Pro Racer / Schroth Profi II-6 / BMW Alcantera Wheel / Cool Shirt / ESS Fire Supp / Solo DL |
