      04-14-2024, 11:14 AM   #1
Unaligned_E46
Unaligned_E46's Avatar
Drives: e46 330ci
E46 No crank no start
So mine isn’t an M but I did a motor swap from a sulev to a non 3.0 engine Ms45.1 and I finished the swap got everything hooked up and did an ews delete and flashed the ecu. I’m thinking it’s gonna start. It didn’t but instead I got hit with these three codes.
281D
DME: BSD generator: signal
present
present
281C
DME: Bit-serial data interface (BSD)
signal
27B7
present
DME: Fuel-pump relay: activation
The starter makes a really loud click but doesn’t crank what do I possibly do to fix this.
      04-15-2024, 05:42 PM   #2
mapster37
mapster37's Avatar
Drives: F80
First i would check all your grounds
      04-16-2024, 03:21 PM   #3
DB_Cooper
Drives: F87
281D
present
present
281C
signal
27B7
present
Where are you located?
