      05-10-2022, 08:44 AM   #1
E46/M3orBust
E46/M3orBust's Avatar
Drives: 2004 E46 M3
(SOLVED) Loud banging noise coming from rear when accelerating and reversing
So I've seen on a lot of online forums where people address this issue. They always assume it is the subframe but I had this exact same problem and my subframe was reinforced less than 10,000 miles ago. It felt like my entire rear subframe was moving each time I accelerated or reversed. So I put it up on a lift and had someone accelerate and found the issue to be the Differential mounting bushings were very worn and the mounting hardware inside the bushings was moving hitting either the top or bottom of the mounting sleeve. If you have this issue get the car up on jacks and check those bushings under acceleration. I didn't have the tools to press these bushings out so I went ahead and just bought a new diff cover with brand new bushings already on. Hope this can help someone
      06-07-2022, 09:11 AM   #2
jp1984
506
Drives: an E92
Thanks! As all of our cars get to being 20 years old, this information is helpful. good job!
      11-02-2022, 07:11 PM   #3
NealfromNZ
NealfromNZ's Avatar
New Zealand
527
Drives: 2016 F80 M3
The diff bolts on the earlier M3s can also cause play and knocking sound. Later diff bolts help to remove the play.
http://www.psdesignsglobal.com/_shop...f-mount-bolts/
