12-20-2020, 02:01 PM | #45 | |
2511
Rep 4,381
Oil consumption is limited and monitored...if any car exceeds the limit during qualifying or the race then it will be excluded. The battery storage is regulated. If any car exceeds the limits during qualifying or the race then it will be excluded. DAS was legal under the regulations in 2020 but the FIA decided to exclude it from 2021. Any driver who achieves a 0.00 reaction time to a start will be deemed to have jumped the start will receive a penalty. The regulations are the same for everyone. It shouldn't be that hard to understand...maybe try pointing to the words with your finger and saying the words out loud to see if that helps. |
12-20-2020, 02:06 PM | #46 | |
60055
Rep 19,541
///M Power-Belgium63356.50 EdM54066.00 |
12-20-2020, 02:13 PM | #47 | |
2511
Rep 4,381
But thats the nature of forums. Myself I'd be a bit more cautious about labelling Todt and the FIA as corrupt. The Forum Admins can get a bit twitchy about hosting libellous comments...especially as the FIA can get quite feisty about that sort of thing. |
12-20-2020, 02:42 PM | #48 | |
63357
Rep 24,667
"KEES" is a die-hard MAX-fan . He said : I'm worse ! Sadly as you know this season COVID was involved . This means a NO-GO ! As far as I know : KEES is "NOT" an idiot . He's our International ISO-editor and one of the smartest persons I ever met ..
M5Rick60055.00 |
12-20-2020, 03:42 PM | #49 |
63357
Rep 24,667
That must be # 47 ! Such a BS ... LMFAO
M5Rick60055.00 |
12-20-2020, 04:21 PM | #50 |
60055
Rep 19,541
Gibberish 47 lol must be on the herbal tea.
///M Power-Belgium63356.50 |
12-20-2020, 08:01 PM | #51 | |
Driver
2692
Rep 2,714
E90M 6MT Slicktop Single Humper in need of a diet
12-21-2020, 03:08 AM | #52 | |
i'm just saying
5738
Rep 2,634
fuel is limited up 110kg but during the race lift and coast gives quite nice fuel economy that teams can compensate even if there is no SC, VSC or rain.. and of course engine maps were allowed last year as well so it was even easier than now.. Ferrari tricked the monitoring part by lowering the "low peak" of fuel pump so they can increase high peak fuel flow (higher on straights for more power).. and in total it was still 100kg/h.. in 2019 Ferrari had a chance to manipulate that fuel pump that FIA monitors like this.. in 2020 FIA added another fuel pump monitor that monitors the flow.. so teams high pressure pump goes through that FFM and then it goes to engine eventually.. and that FFM uses uses encryption and anti-aliasing technology and at the same time it takes random sampling.. means from low peak or high peaks anytime.. that way average of the flow cant be tricked easily like it used to be.. moreover that part is wired independently and sends these codes to FIA's SDR in the car.. so teams cant see what and how many signals FIA FFM gathers.. literally makes teams blind in that part.. here is a simplified version of the system and how it looks now.. there is a chance of "more" on everything less or more.. but for tires for example.. if they werent monitored that well teams could go to that side as well.. but FIA keeps track of each tire.. so all in all.. that area is not very very limited.. teams go in different direction to find time.. and the smart one is increase thermal efficiency and its durability which Merc' did..
"Race car driving is like sex. All guys think they're good at it." Jay Leno
12-21-2020, 03:13 AM | #53 | |
2511
Rep 4,381
But yes, for the FIA its a constant battle updating the F1 technical regulations to best enforce the most equal playing field possible. [1] Typically through after crash inspection, photography and high speed film of opponents cars but most effectively by poaching other teams key personnel. |
minn1914034.50 |
12-21-2020, 03:25 AM | #54 | |
2511
Rep 4,381
The FIA have lately been reducing the amount of "oil" that can be consumed during qualifying and the race year by year. Plus I would suggest that its likely that Ferrari were not the only ones to benefit from this particular wheeze. |
12-21-2020, 07:16 AM | #55 | |
i'm just saying
5738
Rep 2,634
for additive part like in old times, yes probably they do it more cause they could add more additives especially in 1980's.. but with basically something like a rocket fuel.. cant remember its name it should be something tiolin, taulon or something i need to look cause im a designer not a engineer or something.. with those fuel on board burning oil limit was at least 15-20 times higher than now as well but when you add the fact that actually those fuel mixtures they used in 1980's all had some diesel in it as well you can guess how complicated the engineering part.. squeezing more than 1400hp out of 1.5L engine with almost 6 bar of pressure is ridiculous even now.. this burning off oil is especially useful for 2-stroke racing engines you can find in karting races even if most of them are 4-stroke now.. when i was younger (sadly) on 32hp super-light karts.. their fuel is highly mixed with oil and at least once in 2 laps during the race you need to lift and coast and block the intake with your hand while braking for a second at most to fill up the chamber with higher fuel and oil to cool the chamber and the engine of course.. and again causes a puff of white smoke.. this engine oil "thing" is much more complicated than it looks.. i had a small connection with Mobil 1 back in days and tech and chemicals they balance in fully synthetic oils were impressive.. so using these chemicals for gaining more performance is pretty easy if there wouldnt be any restrictions in F1..
12-21-2020, 07:37 AM | #56 | |
2511
Rep 4,381
On oil burning...I was reading that some teams had an auxiliary oil tank and valves in the inlet manifold to inject oil with octane bosting additives. These have since been banned. |
12-21-2020, 07:46 AM | #57 | |
63357
Rep 24,667
Later , the complaints of the other teams and drivers made it in the media . It took 5 months ! Half the season ! It's a shame for motorsports , that the Ferrari drivers and team rankings remained while the FIA knew that Ferrari was cheating . Ferrari had just to remove the Jet-Mode...That was the agreement ! Once the Jet-Mode was removed . The prancing horse ran in slow motion..
M5Rick60055.00 |
12-21-2020, 08:04 AM | #58 |
63357
Rep 24,667
12-21-2020, 11:40 AM | #59 | |
Driver
2692
Rep 2,714
12-21-2020, 12:18 PM | #60 | |
60055
Rep 19,541
12-21-2020, 01:09 PM | #61 | |
63357
Rep 24,667
Crazy COVID lockdown ! Food stores are overloaded with people to store food supply ! Most stores are sold out , stock is empty ... Disaster !!!
M5Rick60055.00 |
12-21-2020, 01:11 PM | #62 |
Rep 1,397
12-21-2020, 01:38 PM | #63 | |
60055
Rep 19,541
In my area we have been brought up in one week from tier 2 to tier 4 which means just ONE visitor allowed for Christmas but plenty of foods in shops here with a 'traffic lights' system before entry to shop and a norm of around 3-4 minutes wait. |
12-22-2020, 05:09 AM | #64 | |
63357
Rep 24,667
=>https://news.sky.com/story/covid-19-...ation-12161566 => https://www.nytimes.com/2020/12/20/h...n-variant.html Vaccine ? Will take years before everyone is vaccinated . What are the side effects after a few years ? I don't believe in the vaccines...
M5Rick60055.00 |
12-22-2020, 05:14 AM | #65 | |
63357
Rep 24,667
Crazy situations ...Cause is the new Covid mutation in the UK .First cases showed up also in Belgium ! See my post above ...Ain't no good !
M5Rick60055.00 |
12-22-2020, 05:24 AM | #66 |
60055
Rep 19,541
Yeah, if Bojo (our PM) put us from tier 2 to tier 4 in the space of just one week then you wonder WHO he gets his info from.
