      08-12-2020, 03:18 PM   #1
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
794
Drives: BMW M3 JB 04 Coupe
Hey guys,
I have been having an issue over the last two years gradually. The water temp starts going past half way mark with the AC on. I have had the car since 2006 and never had this issue. The car has approx 48,000 miles. Temps here are around 115-125f with high humidity. Again never had this issue before. As soon as I turn the ac off the water temps
Drop to below half or half in a minute. I have changed or checked the following things:
New water pump
New thermostat
New condenser
Radiator is good (checked by swapping with a good rad from another car)
Expansion valve for ac changed
Drier changed
Oil cooler is good
Everything is clean too and has been cleaned again.
New ignition coils and spark plugs
Oil is new
Coolant flush has been performed many many times using vacuum method and old Skool with nose up and heating on.
No coolant loss
Car makes great power.
Any other suggestions because the only things I haven't changed are the compressor and evaporator but the ac works perfect and blows cold air no problems.
Any advice would be appreciated because I am really frustrated and in just want my car to be back to normal.
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      09-01-2020, 11:57 AM   #2
Eddien123
Drives: F30 335 6MT
Does the car overheat if the AC is on and you're driving? Or just standing still.
      09-04-2020, 04:16 AM   #3
0-60Motorsports
Bahrain
794
Standing still it overheats and then when driving it'll start at 3/4 water temp but then start dropping slowly.
So the problem might be solved finally. I'll report back once the parts arrive.
Current Mods:
IG: @060Motorsports
      09-21-2020, 02:24 AM   #4
Kewl X5
Drives: X5
Is the aux fan turning on with your A/C? Check the fan or fan resistor....just a thought.
      09-21-2020, 05:40 AM   #5
0-60Motorsports
Bahrain
794
Yes it is. I replaced it with a brand new one. Result was the same.
Current Mods:
IG: @060Motorsports
      03-02-2021, 04:32 AM   #6
k1k1
Drives: e46 m3
Did you ever find the answer to this problem?
My E46 overheats with the AC on too, but goes back to normal once I turn off the AC.
Iv changed the Aux fan, fan clutch and fan controller.
      03-02-2021, 04:33 AM   #7
0-60Motorsports
Bahrain
794
It was the alternator for me. Once changed everything was fine but I can still not give you a 100% thumbs up as I need to test it in the heat. That'll be May onwards here in Bahrain
Current Mods:
IG: @060Motorsports
      03-23-2021, 10:42 PM   #8
Andrew
Moderator
Andrew's Avatar
433
Drives: E46 M3 / E92 M3
2003 BMW M3  [0.00]
2008 BMW M3  [0.00]
What does "overheat" mean? Your car may not have done that in the past, but a little past middle is normal especially as the car ages. Do you know what the actual temp you're reaching is?
I would also try doing distilled water and Water Wetter. A lot of people including me have have success seeing lower temps.
[Track] 03 AW/CIN 6MT E46 M3
[Street] 08 AW/FR 6MT E92 M3
[Tow/Overland] 23 Toyota Tundra HV TRD Off-Road
      03-28-2021, 05:12 PM   #9
0-60Motorsports
Bahrain
794
It reached a displayed temp on the OBD to about 95c and rising buy would drop when driving. Everything is brand new. I'll try the distilled water and water wetter in a month or two as the temps here start rising.
Current Mods:
IG: @060Motorsports
      08-05-2021, 11:13 PM   #10
dsphil
Drives: BMW e30, e46
Any update on this? I am having the same issue.
      08-06-2021, 05:19 AM   #11
0-60Motorsports
Bahrain
794
No updates. The issue is the cars not making enough amperage to power the aux fan to full speed so that's causing the overheating for me. No voltage drops or battery drain so it's very hard to diagnose. Car is parked up at the shop and they work on it when they get a new idea. Every earth connection on the car has been checked and verified
Current Mods:
IG: @060Motorsports
      08-31-2023, 05:30 PM   #12
0-60Motorsports
Bahrain
794
Problem solved, it was the alternator. Changed to 140amp X5 alternator and all good even in 125f temps with high humidity.
Current Mods:
IG: @060Motorsports
